I inherited an older model Unisaw. Is there any hope for it?
Without pictures and a description of what you have, what works and doesn't, the state of electric motors and switches and moving parts, it is unlikely anyone can provide any meaningful advice.
Yes I own one that came out of a school and it works great as long as everything is in working order go for it. I also installed a new fence, riving knife and guard for safety. cheers
I have been using it. The model number is 34-801 and it is wired for 220v. I bought a delta 30" fence and the blade is parallel, when rotating tooth front to back. The fence is parallel to the miter slot. The run out is evident when it slows down. I'm also notice that cross cuts come off about a 64th+ off on 8/4 stock even if the blade is at 90 to the table. Attached is photo. Thank you.
