What finishes are recommended for bowls and platter?
Is it true that all finishes that have cured properly are safe?
Thanks for the input!
I once heard that walnut oil was (one of) the safest finishes to use on anything that would come into contact w/ food. Probably got that out of FWW - long ago. I can remember in HS woodshop, guys were using regular ol' vegetable oil on their cutting boards they made for mom. Not certain I'd go that route though - spend the extra dough & go w/ walnut oil. You know, come to think of it, it may have been a book by Peter Child on woodturning. Not sure if it's still in print, but the library may have it.
All finishes are considered safe once they're cured. Bob Flexner has an article on the subject at this link - http://www.popularwoodworking.com/features/finish3.html
Cutting boards and similar items are often "finished" with mineral oil or a combination of mineral oil and wax. Here's an article on this - http://www.whatscookingamerica.net/CuttingBoards/AllAbout.htm
Paul
F'burg, VA
gotta be careful with walnut oil. Some are allergic to Nuts and the oil contains those that agrevate allergies. Consider food grade mineral oil
So right! I used to tell folks they could use any food oil on a regularly used and cleaned cutting board. Then i had a tenant who knew she was highly allergic to peanuts, yet died from eating them in a soup in which she hadn't even tasted their presence. I began doing a peanut-oil warning for the cutting boards i sell.
Not only is there that to consider, but any nut or vegetable oil will eventually spoil. Don't use anything but mineral oil and perhaps wax.
