Salvage this motor for something?
We’re about to junk an old washing machine. Is there any future for the motor in a woodworking shop? I kept the motor and blower from our old heater, but don’t know nuthin’ about washing machine motors.
forestgirl Another proud member of the “I Rocked With ToolDoc Club” …. :>) you can take the girl out of the forest, but you can’t take the forest out of the girl 😉
Good luck trying to wire it! Been there........
Norse
Doesn't sound promising so far. It has to have a high probability of being used for me to go to the hassle of removing and storing it! Thanks.forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
FG,
Don't be discouraged...it's just the right height for your other foot to rest on while at the workbench...lol
One of my prize posessions is my buffer, which is powered by a washing machine motor from the Ovid, New York dump. It is a slow speed motor that represent all of the above problems. I took it to a friend who knows a whole lot more than I about which screw to hook the wires to. After he showed me how to hook it up, I built a stand with a mandrel on the top that had a hard felt wheel on one end and a soft wheel on the other. After I am though sharpening whatever on my waterstones or my Tormek, I take it to my buffer. You can't believe how well it works. If I haven't bored you to death with this diatribe, let me know, and i will tell you the rest of the story.
Bob
Oh, please, tell me the rest!forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Well.....If you insist! I wasn't really trying to hide anything, just wasn't sure how much interest anybody had in the subject. Obviously, the purpose of the thing is to sharpen chisels, knives, plane irons, or whatever fits.
Some years ago, I went to a woodworking show, and there was a guy there demonstrating a sharpening system using a hard felt wheel and red rouge, so I set out to build one. It's a simple stand with a small grinder on one end and the buffer on the other. The hard felt wheel is for chisels, etc., and the soft one for polishing.
I don't enjoy sharpening, and look for the quickest and best way to do so. I gave up waterstones and "scary-sharp" and bought the Tormek, but the Tormek doesn't put a good finish on the tool. That's where the buffer comes in. I use the buffer free hand. This requires some initial experimentation, but as in many things in woodworking, listen to the sound it makes. When you have the tool at just the right angle, a resonance is set up that I refer to as "singing", easy to describe but not very meaningful.
Suffice it to say, it puts a beautiful shine on the tool, and after I have finished with the Tormek, the buffer requires about two minutes for the typical chisel.
Oh do tell us the rest! I'm gathering up my chisels while you write, how far are you from Trumansburg?
Norse
I'm about ten miles from Trumansburg in Ithaca.
Bob
I don't think so! A wash machine motor has to many wires and different speeds to know what wires to use , beside some have no outer covers. I kept a motor for a cloths drier and pourparler and I'm setting it up with the dust collector from the furthest distance from the dust collector to help move the dust from the table saw. And I saved two squirrel cage fans from a furnace with motors and have put both to good use. But not every thing you save is not a waste, it just might take some time to find a good use for them, I've kept thing for years before I find a use or get time to set it up. Guess I picked that up from my Grandfather on Mom's side , and he was handy fixing things.
IIRC there was a cover story in FWW years ago about recycling appliance motors for woodworking machinery. It had tips about how to decipher the wiring harness and test for obviously bad motors. There was also a short piece, just a picture and a paragraph or two, about a guy who had built some kind of wood cutting machine with two washing machine motors because one didn't have enough torque. So it can be done if you're willing to climb the learning curve.
On the other hand, if you don't already have a use in mind, and given that your shop isn't very large, maybe you should ask yourself, What's the worst thing that could happen if I throw this away?
I'm not dying to keep just for the sake of keeping it. Just don't want to throw it away if there's an obvious (to you guys!) reason to keep it. For instance, I was smart enough a couple years ago to not let the furnace people take away the motor and blower from the old furnace after they installed the new one. I know that those two can be used for 2 or 3 different things "eventually". I'll have to think about the buffer idea. One thing for sure, if I take the motor out, the washer will be a lot easier to load into the trailer for the dump trip!forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
There is likely a wiring diagram inside the pothead (wiring cover).
Sounds like a lot of you guys are avid viewers of the Red Green show!
Waynels, Who or, what is the Red Green show? I live in Connecticut and have cable Is it a D I Y show? Stein.
It's a Canadian comedy show. It's on cable if your area carries Canadian stations. Red Green is a character who is always making stuff out of junk, like a tinkerer.
Its on PBS sometimes too.Steve
Thanx Wayne, I googled it up and ear marked it.
Will try PBS. Those guys look like a heap of fun.
Just got a DVD burner and want to record all their episodes.
Stein.
f_g,
Keep it (with as much cable as possible - saves the hassles of a rewire to some extent)
They also make good lathe motors - good low down torque.
Cheers,
eddie
Hi,
Just wondering if anyone has a copy of the article or any good websites about wiring washung machine motors. I have two that I won't mind using for a buffer if I can get them wired?
I think any motor is worth keeping - you just never know.
thanks
edcross1
Sure thing F Gurl, It's more than likely a two speed induction motor. Can be bench mounted and with an arbor attached to it's shaft, can serve as a wire wheel brush/polishing buff/grinding wheel/or a horrizontal sanding drum or all of the above.
To mount the motor, use big enough hose clamps (TWO)mount it to a wood block base .I use two each for each end by attaching them together to create a larger clamp. The arbors are sold in sears you'll want one to fit a 1/2" shaft .Be sure to mount the motor so the wheel spins downward as it travels. ED
a new buffer/grinder..sweeeeet....belt it to an arbor with a 3 step pulley..hard felt wheel and rouge and theres your final strop on a plane iron..
Save the drum from the washer. They make a great b.b.que or fire pit. The holes in the sides allow oxygen into the fire and they really radiate alot of heat
There should be a wiring diagram on the back of the washer somewhere. Keep a copy of it - either the back itself or take a digital photo of it if you have a digital camera. Look to see if there are any parts that need to go with the motor - like a capacitor etc.
Randy
It's me Stein. again FG, Don't be discouraged, Think or it as a learning experience. You don't need a belt step pulleys or a mandrel. Just the motor, and the arbor ($4.00 at Sears.) it attaches directly to the motor's shaft by tightening two set screws.
The motor is powerful enough to do a giant load of wash, so it can just do great as a buffer or grinder or a wire wheel/I once Used two of those motors coupled together to increase the power to a home built table saw.
Incidently that furnace set up from your old oil burner is perfect to build a gas fired forge to heat and harden or bend metal. Google up Keen Junk G'Luck Gurl. ED.
Forest Girl,
This is a shop built spindle sander with a washing machine motor.
Eagle America sells the plans ($11) and the hardware (if needed). http://www.eagle-america.com/html/catalog/productGroup.asp?id=334005
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
