I recently rescued an OLD beech butcher block countertop from the landfill. It was found when a laundromat near my work was remodeled, it was supporting 2 washing machines over a weak section of floor. It has survived remarkably well, and I want to make a workbench out of it. It is quite large (75″x 24″x 2 1/2″) and VERY heavy. It is structurally sound (glue joints are solid) but uglier than a mud fence. What was at one time the “top” has been hollowed out somewhat from years of butchering and it is generally beat up, so I plan to take it to have it planed flat. And since I don’t have room for a 6’3″ bench, I want to trim it to length. My questions are as follows:
Is there a minimum thickness I should stay over for strength?
What is an “ideal” length?
It currently has 3 threaded rods running through it at the center and ends. Will cutting the end sections off and eliminating the end rods run the risk of the top splitting over time? Would breadboarding the “new” ends be as strong?
Other than good solid legs and the requisite vices and dog holes, is there anything else I should consider adding?
THANKS IN ADVANCE!
Woodhoarder
Edited 1/10/2005 8:15 pm ET by woodhoarder
If you dont have to shorten it leave it,as for the hollowed side of the table why dont you flip it upside down assuming it is flat.A few years ago I had the good fortune of saving a door jamb from an office tower and to my surprise the wood turned out to be Mahogany at 21/2" th x 7"w and a total length over 25'long and made a queen size bedframe from it. The moral is one mans junk can be another mans gold.LOL.
