I have a hard translucent stone for putting the final edge on my chisels and plane irons. I guess I didn’t charge it sufficiently with oil and now it’s clogged with metal. I’ve tried several remedies to restore the stone including a parafin bath and scrubbing it with mineral spirits. Nothing seems to work. Any ideas on how to restore the stone? Thanks.
Salvaging a sharpening stone
I've flattened several waterstones recently. I would suppose to flatten an oil stone, the process would be the same. I use 220 grit wet dry sandpaper on a flat surface. I bought a granite stone made for this purpose. Wet the stone and sandpaper so it stays put. Mark a grid on the stone with a pencil for referencing the high and low spots as you rub it on the sandpaper. Rub the stone for a few strokes, check it, and when the pencil lines are gone you'll have a flat stone. Hope this helps.
