Hey all, I read that Sam uses a blend of, one part each, tung oil, linseed oil and polyurethane for his finish. He brushes it on, then with a clean cloth wipes it off. My question is, how long do you let this mixture stay on the wood before you wipe it off? How many coats do you apply?
Thanks, Jim
Jim,
Here is a link to a prior discussion about this.
http://forums.taunton.com/tp-knots/messages?msg=1416.1
TDF
Rockler has worked with Maloof on a line of his finishes for several years, try here:
http://www.rockler.com/ecom7/product_details.cfm?&catid=53&objectgroup_id=315&offerings_id=2004
LRSmith
OK...I got the linseed, tung, and poly blend working well. I used 4 coats. Now does anyone know what the proper mixture for the linseed, tung, beeswax blend?
Jim
Jim,
Here's Sam's description from
"Sam Maloof, Woodworker," Sam Maloof, Kodansha International, 1988:
" The . . . mixture is equal parts raw tung oil and boiled linseed oil to which I add shredded beeswax."
(I believe he actually used partially polymerized tung oil.)
"Because I add the beeswax by feel, much as a cook seasons a sauce, the reader who wants to try my method will have to experiement. The final result is a mixture with the consistency of heavy cream. The oil mixture is heated to melt the beeswax. The safest way of doing this is in a double boiler or electric hot plate. Always do this outdoors in a clear, safe area. Avoid using an open flame. Linseed oil has a very low flash point. BE VERY CAREFUL! Heat the oil just until the beeswax melts. The oil and wax homogenize readily. I store this mixture in a gallon can and apply it cold. It is not necessary to reheat it. It has a very long shelf life; I do not know exactly how long because I am constantly making and using it. Stir it before using.
VL
FWIW, I've used the Rockler product (oil/poly) on two recent projects and it is a wonderful finish, both easy to apply and very nice when complete - it gives a very warm appearance and feels great to the touch.
The instructions call for sanding to 400 grit and burnishing with 0000 steel wool, apply liberally and wipe several times. I generally wiped it on with a blue shop towel and wiped it off after 5-10 minutes. In both cases I applied four coats. Neither project had any top coat as they weren't items destined for much abuse or contact with liquids. Here's the latest - a golf ball display case from hoduras mahogany.
Eric
