Is there anyone who sells plywood that has all the veneers the same species? There have been many times where I had to try and “hide” the edges. Usually without much success.
Don
Don
All the fir ply I've ever worked with was all the same species.
Baltic birch is all the same species. I'm sure there are others.
But I think your problem is the contrast between the end grain and
long grain, and using all one species won't help that.
You could make plywood with the grain in all layers running the
same direction (laminated gunstocks are made that way, or at least
with a much less than 90 degree angle between layers), but it
wouldn't have the mechanical properties that we like plywood for,
and it would still look like a lamination.
The latest Fine Woodworking magazine has an article on edge
treatments for plywood. Another possibility would be to apply
whatever kind of edge banding you like and then veneer over the
face and the edge banding. If you used end grain edge banding on
the ends of the panel, you could make it look like a solid wood
panel with a decorative veneer. Just to keep people guessing,
you could orient the growth rings in opposite directions on the
two ends. Or have wide boards at one end and narrow boards at the
other.
I recently built a filing cabinet from birch plywood and used 1" maple strips to dress the edges of the sides and top, and 1/2" for the drawer fronts. It added nice contrast while keeping the cost down. You can see photos of it under the Gallery section.
Thanks for the reply guys. I probably didn't make myself clear on the plwood edges question.
I plan to make decorative fret sawn/scroll saw trim that will later be steam bent. I need 1/2" plywood in ALL cherry veeners and also walnut. At present, I haven't been able to find any cherry and/or walnut veener to fit the bill. All have a fir or MDF core. I can't "hide" the edges. If all the layers were the same species, I would be all set to go.
Does anyone make such plywood?
Don
The only other option i can think of is basically making bent lamintations for your product. But i say this only as speculation since i dont know what youre making.
Hiding the edges in plywood will always be difficult with intrigate parts due to the Endgrain and the long grain contrasts. They will always be a bane on edge concealment of intrigate scroll/fret type work
