Though finishing is not my first love, I’ve learned to get a good looking finish on table tops by working up though the numbers (to 4,000) with Abralon pads. They are great.
But, the contoured edges, ovolo etc., are a different story. How do I get that phony, high gloss finish off them without losing the crispp shadow lines?
Jerry Frustrated Frost
you really should knock some of the sharpness befor starting the finishing. Now use steel-wool.
Jerry ,
As Keith has said , you should sand the detail out by hand as best you can without changing the profile before finishing . I use a scotchbrite type of sanding pad for the detailed parts between coats of finish , it gets in all the areas but won't change the shape at all .You might use a really worn piece of sand paper first depending on the detail.
give it a try dusty
Edited 7/15/2005 1:20 am ET by dusty
Thanks. I'll try the steel wool. The top has a nice sheen to it but the edges show the gloss from "untouched" gloss finish. I don't like that look.Jerry
Just what I have use sometimes so 'try before ya' buy'
Some oil, wads of cotton balls, and Rottenstone... I think if you use water it leaves the gloss? I could be wrong on that.. I have been wrong MANY times..
