I need your help. I have received a belt sander and disk sander combo, it is a craftsman. It belonged to my brother-inlaw’s Father, he was also a woodworker. My brother-inlaw has given me all of his father’s woodworking tools. The disk sander dose not have a sanding pad on it but there is an orange adhesive that has harden that needs to be removed. Mineral spirits did not work, do any you have an idea how to remove this adhesive?
Hi Handy.... There are several adhesives that could be 'orange'. The first is contact cement, the second, 'sanding disk adhesive. In either case, if mineral spirits did not work, first try denatured alcohol, second try laquer thinner and finally, acetone. These are progressively 'stronger' solvents. In ALL CASES, do this outside where there is LOTS of fresh air moving around to dicipate the fumes. If all else fails, sharpen a 'scraper edge' on an old file and make up a 'tool-rest, just like a lathe. Take a couple of LIGHT, EASY passes and all the crud should come off. Disk adhesive comes in a large stick, similar to polishing compound or a sanding belt cleaning 'rubber'. You would turn on the sander, apply the stick adhesive to the spinning metal disk. When the metal disk was covered with this stuff, you immediately shut off the sander and press the sandpaper onto the softened glue. Messy, but it works. I prefer good old rubber cement. It's cheap, easy to apply and comes off fairly easily. SawdustSteve
Thanks Steve, that sounds like a plan.
Warning ! Toluene is a product I use as little as possible, as well as most other nasty solvents. And then only with gloves and an organic/chemical respirator. Prolonged use can cause permanent brain and nervous system damage.
An after thought. Try a heavy duty heat gun, It's worked for me.
Bruce S.
Edited 5/15/2007 6:07 pm ET by BruceS
Prolonged use can cause permanent brain and nervous system damage.................
So that explains why my mind is like it is. I had a suspicion it got worse after I made a tea out of the stuff. Taste purty good with cookies though. <g>
Cleaners that contain toluene will remove just about anything. They are often sold as paint brush restorer.
