I built the bedside table in August Woodsmith. It Turned out great. I wiped on 10 or 12 coats of satin poly. My wife said she would like a little more shine, so I wiped one coat of gloss poly on the top only. Still looked great. I wiped on two more coats of satin over the gloss on the top before the final coat. I decided to make the final coat a little heavier. Mistake! I had some runs on front corners and sides of the top. This is top only. I Let it dry and sanded the runs level and then wiped on another coat of satin. Then I could see where the runs had been even though the area was smooth. I Let it dry overnight, sanded with 400 grit and rubbed with steel wool until almost all signs were gone. Could still see some shiny spots where I had sanded, but thought I was seeing some gloss and some satin. I wiped on another coat of gloss thinking that would make it all shiny. No! I can still see streaks (or river appearance) when looking at an angle. Problem is only in corner and side areas of the top frame. Ruined a perfect job. I Can’t sand the whole top as is Cherry plywood surrounded with solid cherry frame. I have no problem in center anyway. All the runs were on the frame. I Don’t know if the streaks will disappear with more coats or will simply pile up more poly on the problem. I don’t want to make it worse with more sanding unless that’s the only way to fix the problem. Any way to save this project without totally removing poly from frame? I fear that may make the problem worse if I sand down to jel stain and accidently sand through. Can anyone help? agriffee
Have you tried using a sharp scaper? It works well for me.
Sand paper tends to round over the high spots, a freshly sharpened scaper will clean it off nice and level, and take just the run. Use a light source at an angle to help you see the run and the progress.
On curved areas, might need a curver one, or use a sharp chisel.
Good luck with it.
Curt
I agree that a scraper is the best way to deal with runs and sags. But, lacking a scraper... one can make a one-sided razor blade function close to the same. Or you can wetsand the run/sag with mineral spirits. The MS will lubricate and cause the sandpaper to work mostly just on the high points of the run or sag. Actually, I would recommend wetsanding lightly even after using a scraper.
Kevin
Ouch. What Curt says.
The scraper suggestion is good advice BUT that is the tool you should have used instead of sandpaper to level the runs followed by light sanding to feather out. But now you hve a problem that is covered up with several layers of poly. How are you going to fix it? Since you can't sand off all the finish due to the plywood, you will have to use chemicals to strip it.
Your problem is the number one reason I don't use poly. I have experienced the same thing. Runs and drips are always going to happen when we wipe or brush. I have switched to HOT finishes like laquer and shellac. HOT means, each coat melts the previous coat and will blend in any sand thru areas you have touched up from sanding funs. I typically use high gloss brush coats until the final coat and then use an aersol spray can for the last coat. If I want a satin finsh, I only apply satin at the last coat. This is better than using satin for all layers because satin finishes contain silica sand to diffuse the light refraction. Many many coats of satin will cloud the finsh. You can also achieve satin with all coats gloss if you steel wool the last coat with 4/0 and lubricant like mineral oil on the final coat. It is sometimes difficlut to steel wool tight crevaces though to achieve the satin look. If a stain finish is desired I usually spray satin as the last coat. With laquer, some guys, with spray equipment, will spray straight 100% laquer thinner over the dried last coat to melt the surface and it will level out near perfect without alot of rubbing.
Stick with any HOT finish and sand thru problems will be eliminated. Drawback to my suggestions are, laquer is smelly and shellac disolves with acohol but both are very easy to repair and touch up. Poly is not repair friendly.
Hope this helps,
Don
I just couldn't bring myself to strip that top. Don't think it was bad enough to risk doing that. The top is dyed, stained, and has multiple coats of poly. Importantly, it is assembled and would be very difficult to avoid causing more problems. I could only see imperfection from a side view point and the table is in a well lighted shop. It will be in my bedroom which is not as well lighted.
What I did: I carefully sanded again, put on another coat, waited until was almost dry and wiped on poly in bad spots. Then I wiped it off with a slightly damp mineral spirits rag. That sufficiently dulled or marred those problem areas so that the next two coats have just about eliminated the problem. I'm not sure yet if will totally correct problem as am still putting on gloss poly.
I didn't know that satin poly clouded the finish and never thought about scraping off runs. Learn something every time I go to Knots. Thanks very much for your help. agriffee
If anyone ever sees this and asks you about it, say it's your "trademark".
Keep doing it that way, and in 100 years, on Antique Road Show it will be worth alot more with a few dull spots. Your relatives will thank you.
Really only a comment about knowing when to realize that you are "close enough" to start enjoying using the piece and that it's time to get on to the next one.
I always wondered what that stuff was in the bottom of the can of satin poly. <G>
Edited 9/22/2003 4:14:20 PM ET by johnnyd
You're right. Time to bring it in and watch the wife lay a cover on it, pile up flowers and other junk to cover up all that pretty finish I worked so hard to get. Ha-Ha
Actually, think I talked her out of the cover since I gave her the shiny gloss look. It turned out almost flawless after a few more coats by the way. agriffee
I've got a project going with a really nice piece of figured maple plywood. It's a counter top with backsplash and side splashes all of the figured stuff, and edge banding out of regular maple sticks. Got to 220 ROS last night over the initial coat of shellac sanding sealer, but the edge banding is uncoated yet. Wondering if I should put another coat of shellac over all before laying the semi-gloss (Varathane "floor") poly on. The figured ply is actually a little wavy.
Seems to me that sanding sealer is necessary for two reasons, to seal in something like a water base dye, or to keep material from soaking up too much, ie: stain, etc. However to get the same color you may want the shellac on banding as well. I usually do a sample piece. Regards, agriffee
