hi there!1
I`m a beginner woodworking student and the other day we built a bookcase which was sanded after being assembled. I was wondering: isn`t it much better to sand all the parts with all the different grits before assembling? then putting the whole thing together? I found it extremely hard to sand the the bookcase as a whole. I would apprecciate getting help as to when to apply the sand paper and what grits i should use. Thanks.
Acoder
You are correct. I'd recommend sanding prior to assembly. In fact, that's the topic of the latest episode of our series Getting Started in Woodworking. Take a look, it should answer your questions.
http://www.taunton.com/finewoodworking/getting-started/season-two.asp
