I have allot of Lasewood.. Nasty for my lungs but a wonderful wood to work.. Untill it wants to chip out!
I wipe it with Acetone before I do a glue-up.. The rag turns pink.. Nothing PINK about it! from what I see!
Any reason why? Maybe shipped to American and crying to get back home?
Will:
I's crying to be shipped to our shop! It misses the mountains that's all.
Madison
Sapele colours vary from pink to brown. I think one can safely assume that this is due to the proportions of different pigments. The acetone is dissolving a pink pigment out of the wood.
If this causes a problem you might want to try another solvent. Alcohol and mineral spirits should also remove oils but might not dissolve the pigment - or they may dissolve other pigments instead!
Sapele colors vary from pink to brown....
Thanks.. Mine is what I would call .. I have no idea how to describe it. A medium brown and very straight grain. It is quarter sawn and approximately 14 inches wide by 5 foot long. Just under one inch thick. I have five 'sticks' of it left over..
The other 'sticks' were about 8 foot long and approximately 11 inches wide.. Maybe from the same tree but the skinnier ones from a bit up higher than the wider ones I purchased...
That wood was EXPENSIVE!
I asked the question because if I wipe most woods with Acetone, the rag is usually a muddy color of the original wood color. #after removing all the dust I can get off of it#..
With my Sapele I end up with a light color pink stain on the rag..
My brain a bit different? YES! I know it is.. Makes me... ME!
I just wondered about that very noticeable pink stain and not muddied to black or gray...Very light color of pink.
Just for kicks you might want to try a little acid and alkali (baking soda, caustic..) on different spots of the rag. You might get a colour change if the pink dye is an anthocyanin. (Think Litmus).
