Saw Blade Storage System works like a file folder
1/4″ thick hardboard pieces rest in the slots of the bottom rails, and can pivot back and forth. The ends are sloped 10 degrees. The blade sticks up above the hardboard so that the desired blade can be found visually. A blade can be easliy removed and returned without risk of chipping a tooth by contact with another blade.
Made a 2 minute video with a few construction tips and showing the system in action: https://youtu.be/T79zWFL-Gtc
I wish I had enough blades to need such a storage system!
I’m kind of glad I don’t. :-)
“[Deleted]”
Pictures wouldn't load before. Let's try this again.
Even better!
Very cool. Liked the drill press explanation.
Thanks for posting Steve!
