So where do y’all get a saw set from?
I could not find one to buy online but I got lucky and managed to pick up an oldie from an elder gentleman woodworker but it’s kinda sized for a 24″ handsaw. I have a Stanley 42 and I’m thinking I need a 442.
Saws with 12+ TPI need a smaller pin and anvil I figure.
Andrew
I set mine with a fine screwdriver, place between every other tooth and twist. I got that jewel from Tage Frid and it REALLY works.
I found most of my saw filing tools at barn sales but that was a long time ago. I still see some vices, joiners and the odd set or two. They often have a selection at the Jonesport Tool Co. in Maine.
http://www.jonesport-wood.com/jwabout.htm
Have you visited the vintage saw web site? They often have some 42X's for sale, but they are expensive.
http://www.vintagesaws.com/library/primer/sharp.html
As far as I know Eclipse still make a good quality saw setter of the type that you squeeze together like pliers. It has a tiny hammer which presses the tooth against an anvil which can be rotated for adjusting to accommodate different tooth sizes and amount of set.
Always to be seen in flea markets etc.
The anvil in most sets is fine, but it's handy to grind the punch to match the smallest tooth. Usually renders the set unusable for larger teeth, so simply buy another set. In the Southeast US, used, but servicable saw sets are a dime a dozen in antique and junk shops, only those in original packaging bring a premium. Oh yes, make sure you can disassemble the set (Stanley) to reshape the punch. My favorite sets by Eclipse & Taintor are riveted.
Good luck,
John in Texas
Did you look here?
http://www.toolsforworkingwood.com/indextool.mvc?prodid=MS-SAWSET.XX
I don't own it so I can't be sure, but the blue saw set looks a lot like the one Chris Gochnour has on page 94 of the March/April issue of Fine Woodworking, and in his video here at
http://tinyurl.com/s898r
In any case, for $12.95 it doesn't seem like you could go very far wrong.
Dan
Old time saw filers used a tack hammer to set the teeth. They tapped lightly over an anvil.The screwdriver thing sounds like it may be a good alternative.
mike
you can find new saw setters. BLue and Gold. Each color represents the TPI. Gold is fine and blue is large, if memory serves me. Mine is gold does the smaller PPI or TPI.
for a dovetail saw youll need a setter, hammers and such will work fine on ripsaws and xcut saws with low TPIs but dovetail needs a bit more precission
highland hardware and japan woodworker sells saw sets
Thanks to all who replied. It sounds like there are a few alternatives.
Funny, the latest Fine Woodworking had an article about saw tweaking and made no mention of sources for saw sets (which the process depends on). It has taken a bit of effort to find one.
Andrew
