What’s a good blade for sawing logs into flitches? I have a 16″ bandsaw. The logs I have to cut are 2′- 6′, maybe 8″- 10″ diameter maximum, and are oak, maple and cherry. I have a great 3/8″ resaw blade for finer work but I was wondering if I need a Woodslicer 1/2′ or 3/4″ or something else for this rougher cutting. Any advice is greatly appreciated.
Heuglin,
Not sure if you are new to milling logs or not but I recently tried it for the first time. It took me a while to figure out the proper set-up but got some help from Knots on this thread - 47775.1. I found it much easier with a blade designed for green wood, very coarse with a wide kerf. I ordered this one,
http://www.lagunatools.com/accessories/Silicon-Blades/bandsaw-bb107s
but I am sure others make something similar. Call your favorite blade supplier and ask them what they recommend. I was also having a hard time keeping the logs on a straight line as I fed them through the blade. I have seen all sorts of sled ideas but I just ended up screwing them to a piece of plywood, shimming them up so they did not rock and taking a cut keeping the edge of the plywood against a long fence. This ends up taking off a slice of plywood as well but since it was scrap I did not mind.
Hope that helps.
Chris
Thanks for the reply. All good info to consider.
If you want to draw attention, the best thing you can do is mill your lumber and forget about the screws holding the bole to the sled.
and www.flairwoodwork.spaces.live.com)
