I was working in my shop yesterday dimensioning Poplar into rails and stiles on my SawStop. I noticed that I had a number of bandages on my fingers and thumb and was wondering if they could prevent the brake system in the saw from triggering in the event of an accident.
Any thoughts or experience would be appreciated.
Assuming the saw would cut through the bandage and contact your finger the system will activate as designed.
A number of bandages on fingers and thumbs? Sounds like the sawstop was made for you.
*** Warning: DO NOT ATTEMPT THIS PROCEDURE WITH MOTOR RUNNING or BLADE SPINNING ***
The way to determine if the SawStop Safety Sytems will activate:
See Attachment for SawStop PCS Switch Box
1. Start / Stop Paddle in "Stop" position
2. Main Power Switch in "On" position
3. Check to confirm: Motor Off, Blade NOT spinning, Left Green LED on, Right Red LED off. Raise Blade high enough and touch Material to be Tested to Center of Blade - Do not make contact with teeth
4. If Right RED LED blinks when testing Material then SawStop Safety System will activate if it comes in contact with a Spinning Blade
*** If you are uncertain or have any questions call SawStop Technical Support before performing this procedure ***
thank you all for the comments and references.
Re: bandages on fingers and thumb are due to cracking skin that's drying out from sanding
Then stop sanding your fingers!
Seriously, with the really dry air this time of year, mine crack too. I use CA on them, and it helps them heal really fast.
The best thing I've found to help prevent it altogether is Working Hands. I have a lot fewer cracks after I started using it.
Tried multiple creams - they work for a very short while but don't prevent cracking - especially when sanding. Can't really apply cream during the day as it compromises my grip. What does work is polysporin on the affected area under bandage - for a day.
What is CA?
Cracked skin on hands often responds to moderately potent steroid ointments. It is worth asking your doctor if this sort of treatment might be right for you. Vaseline is also very good for hands, especially if applied liberally. Not so pleasant tho...
Vaseline is what dermatologists say is best to heal skin after skin cancers are frozen off with liquid nitrogen or surgically cut off. I know this is true after having numerous skin cancers removed for the last 2 and 1/2 decades. So, when my thumb corner cracks open, I put a band-aid with Vaseline on it at bedtime. (It would just come off while working.) It heals up nicely.
CA = Cyanoacrylate or by the brand name Super Glue or equivalent.
"There are three cyanoacrylate compounds currently available as topical skin adhesives. 2-Octyl cyanoacrylate is marketed as Dermabond, SurgiSeal and more recently LiquiBand Exceed." Source wikipedia.org
CA is superglue.
How much cost it is?
