Wanting to get away from sand scratches- swirl marks- sandpapper.
I have been looking at scrapers and wanting to know if you can finish with the scraper rather than sand paper.
I have used a few of the card scrapers and I like them but would like some input on something like the #80 scraper or a scraper plane to finish larger pieces.
Working with hardwood mainly maple walnut and red oak.
Thanks for your help
Ronnie
I have both the LN 212 and the LN 112. By far my perference is the 112 unless the area I'm scraping cannot accommodate the larger footprint of the 112. I try to get away with hand planing where the wood grain cooperates, however I like reaching for my scraper plane instead of sanding wherever possible.
You should be able to get a very smooth cut if the scraper plane is adjusted properly. The trick is to 1st set a proper hook on the blade and 2nd, adjust the angle and depth of cut. LN suggests in their directions for use, that a new user first get the feel of the scraper plane with just a sharp blade (no hook). I found that the cut angle (angle that the blade is to the surface of work) is the most difficult to master. Even though "an" angle will produce scrapings, it's "thee" angle that will give the best surface result. It takes a bit (OK maybe a lot) of patience with trial and error to figure out what angle settings give the best surface result, and this also depends on what wood it is being used on. By far the easilest scrapers to use are the card type, where one can get direct feedback on the correct angle for best cutting action.
Ron
I agree with the previous reply, that it's critical to get the angle just right. I have both L-N scrapers; one way to get the angle set right is, after you have prepared the blade, hold it your hands and use it on a piece of scrap wood like you would use a card scraper, tilting it back and forth till you get it to produce shavings you are satisfied with. Note the angle at which you are holding it and install it in the plane at the approximate same angle. GP
Ronnie,
I have old Stanley scrapers. I have the #80 and the #112. The #80 does better on heavy stock removal and the #112 is uncomfortable to use but better for finish scraping. The one I really like and use is the #81. It's a good finish scraper and comfortable to use. I like the #81 better than the #112 and it's available for a lot less money. If you want to scrape into corners or similar locations you might look into the LN #85.
A high quality smooth plane will leave a better finish than a scraper. I don't use my scrapers much any more because I have planes that out perform them.
