I am considering the purchase of a scraper plane to flatten the top of a cherry dining table.
The author about scrapers in FW #189 seemed to favor the Veritas since it has an adjustment to allow forming a slight camber on the blade. Lie-Nielsen offers two, designated as a Large and a Cabinet Maker’s scraping plane, which do not have this adjustment.
Does anyone have comparative information about the Veritas scraper plane as compared to either of the Lie-Nielsen scraper planes?
DWB: The only thing I could add is that the blade on the LN is way too thick to "camber". If this is an advantage in other ways I defer to those with more experience, although I believe a thicker blade is less likely to "chatter". I have the LN large model but have not been able to get it to work right for me yet; due to my inexperience no doubt. KDM
"... Buy the best and only cry once.........
The ability to camber the blade is a plus under some circumstances. Maybe even many. LV also makes a thicker blade for a small additional cost.
I owned the LN large scraper plane for several years. Excellent plane. The cabinet maker's scraper was a plane I had considered getting at one time do to the scale of my typical work.
If I were to purchase another--I sold my LN recently--it would probably be the LV due to the blade thing, but I would get both blades. And if didn't have a toothing plane, I would get a toothed blade. With a toothed blade one can quickly waste otherwise hard to plane surfaces such as crotch figure with a conventional plane.
Either company's plane will scrape a surface as good as the other. Neither will flatten a larger surface per se. Think of a scraper plane as an adjunct to final surface smoothing, except they are used in either areas of grain which will readily tear out using even your best smoother, or as a final "smoother" on entire tops where there is risk of tear out.
But they are too short a plane for flattening.
Another option is the LV #80 type of scraper. I probably use this more than a scraper plane. That and hand-held scrapers. I really only used the scraper plane for large tops which had reversing grain.
Take care, Mike
DWB,
I too bought the Veritas scraper plane, mainly because it offered the thin/bendable blade option. I had their other scraper - the one that looks like a big spokeshave - so knew just how much control the ability to bend the blade gives.
It seems mysterious that Lie Lielsen only offer the stiff blade, as the traditional card scraper for finishing wood only seems to work if you bend it a bit. Also, a bent blade not only offers easy fine control of the depth of cut but also prevents tramlines caused by the corners of a flat blade.
Anyway, I can recommend the Veritas as very controllable scraperplane, well made and very easy for even a scraping novice like me to set up and use.
Perhaps a Lie Nielsen scraper plane owner can be persuaded to say how best to use the straight-blade option?
Hi Lataxe,
The thick blade on the LN does indeed work exceedingly well, especially for large flat surfaces. No real need to bend the blade unless one is working locally instead of the entire, or major portion thereof, surface.
Most of the time, I never put a hoock on the blade if I was working something very hard. Else from the hardness of Mahogany or less I rolled a shallow hook.
But--the LV version does allow the thin blade and flex, so that's why if I were to ever purchase another scraper plane, it's the one I would get. I would still obtain the thicker blade for it. Basically the thicker blade one can lightly relieve the corners of the blade [like some do smoothers] for heavy work on hard woods over larger areas.
Take care, Mike
