Hi to all, I’m looking for a alphabet for scroll sawing name plates,any ideals ?thanks ahead of time…. werd!
Werd,
I am assuming you are looking for stencils? If so, try this, go to Microsoft Word and pick the font you want and type out whatever you want it to say. Then highlight your words and right click and go to font. There you can choose the option to outline and it will just give you the lines around your font which makes it very easy to cut out. Also, to help you out, print it out in red or yellow. The black lines with a black blade starts to blend together after a while. Good luck!
Bio
Hi again another ? can this be set up in script/ werd
Werd,
Yes, just find the font that you want and follow the procedure I gave you before. Works like a charm.
Bio
I have been using Word for years and never thought of that. Thanks that is a cool trick.
Bob
No problem, I can post some pictures of me doing it. Works GREAT and it is very cheap. Simply spray mount it to the wood and boom boom boom.
Bio
