Just wondering if this is a laughable idea:
I just ripped up a nasty old carpet that was glued to a nice big oak floor which i’m going to refinish. To get all the glue off i was going to rent a floor sander, but then i got the notion that i could scrub plane all the gunk off – sure it’d take more elbow grease (this is in my house btw) but then i could vaccuum up the shavings as i go and not creat great clouds of glue particles. Then sanding it would be a much easier task.
Maybe this’d take way longer than i’m imagining. What do you think??
Jesse David
Edited 7/8/2005 12:08 am ET by JesseDavid
Talk to a professional floor sander, they run into this all the time. I had to remove the adhesive in one room, luckily only the perimeter had glue. I used a card scraper , any type of solvent couldn't be used as the heat was electric baseboard and the job was in the winter.
mike
Jesse,
I have used hand planes on floors to tackle localized problems with some success. But my guess is that you will find it awkward to try to plane a floor due to the necessary body orientation to operate the plane. I might also suspect that the plane blade and throat will foul with glue frequently.
You might try a heavy duty carbide blade scraper. I have used one to strip varnish from a floor prior to sanding.
Several years ago I had to strip the remnants of resilient tile and glue from an old wood floor prior to restoration. In that case I rented a right-angle grinder and went at it with coarse sanding disks. It worked but produced great quantities of dust.
I would imagine that a decent floor sander with its' accompnaying high-volume dust collection would do a decent job of holding dust to a minimum.
Jesse,
Having put down a few tile floors, I would recommend against it.
It will be really rough on your knees and your lower back....
Get a cheap rag mop and a gallon of lacquer thinner,open the windows and doors, use a fan to vent the space and mop away
Mark
Don't forget the anti-solvent face mask.
OR You will end up high as a kite!
Laquer 'huffer's are at the bottom of the addict's pyramid.
Even crack users look down on huffing.....
Cheers
M.Stehelin
