I am a decorative painter and paint on maple boxes with acrylic and/or oil paint. I was using a sealing product created by one of the artists I know, she has quit producing this sealer. I really liked it.
It is a water base product, dries to almost a sheen, prevents ridges forming from wood grain swell, can be sanded to a very smooth finish, I can then paint it with a background color of acrylic or oil and do my design on top.
Any suggestions as to what to replace this with would be greatly appreciated.
The most common sealer in woodworking is good old-fashioned shellac. I would veer towards the de-waxed variety. Go to a hardware store and pick up some "seal coat" it's a thinned down, de-waxed shellac.
I would suggest cutting it down a bit with some denatured alcohol. Try a mixture of 3/4 seal-coat and 1/4 denatured alcohol. Apply a coat, allow to dry, sand lightly with some 400-grit paper, re-apply, sand again, reapply, and then maybe just buff down the final coat a bit with some #0000 steel wool. I would imagine that would give you a nice smooth canvas on which to paint.
Cheers and good luck!
Ed
Sealer
I would look for a spray can product in the arts and crafts store near you.You're doing small jobs. Not sure of a brand that is water based and won't raise the grain? But that's no big deal - light sanding gets rid of the grain fuzz after sealing.
SA
