Sean Hughto (Samson) Article, or Where can I find this?
Hello! I came across an article entitled ‘Making a Frame and Panel Door’ by Sean Hughto, written December, 2008. (Here: http://www.inthewoodshop.com/Furniture/Making%20a%20frame%20and%20panel%20door.html] “
In this article he says he uses a “plough/grooving plane (mine happens to be a Stanley 248 A)”, then moves on to say, “I run beads, using my 66, full length on the rails:” with this picture:
Here’s where my question comes in. What exactly is this called and where could I find one? I’m doing searches, but coming up empty. I’ve been trying to make beaded inset cabinet frames by hand and innovation, but although I’ve been successful with a lot of sanding, this looks to be a much more sensible method.
Could anyone send me in the right direction here? I think an actual name of the tool would be most handy.
Thanks for helpin’ a chick out.
Christine
You don't need this tool to do what you want
You can simply grind the bead into an old plane iron or card scraper. A card scraper is easier as you can use a file, a plane iron wili require a grinder and you will have to shape the wheel with a dresser. This image is of a plane iron. you can also use a section of an old bandsaw blade mounted in a scratch stock. But the card scraper is the quick and dirty way to do it.
Oh by the way here is the tool you are looking for,
http://www.ebay.com/itm/Lot-of-2-Stanley-No-66-Hand-Beader-tools-with-8-cutters-3-fences-/121142498962?pt=LH_DefaultDomain_0&hash=item1c34a7d692
Lie Nielsen also makes one.
Good Luck
Rob
Thanks for getting back to me.
I'm going to look for the items you've mentioned and take a look at eBay.
This opens a lot of possibilities I didn't know were available.
I'm afraid I just love the beaded look!
C.
hand beader
LN makes a modern copy of the Stanley tool and LV makes their own version of beading tools. May want to take a peak in both directions.
Stanley 66
Thanks.
I actually have that open in another window.
Gotta get a few $$ together and I'm going to pick one or the other up!
I appreciate it.
Hey CEF
I will try again. Save your limited funds for basic necessary tools. A Stanley or Lie Nielsen scratch beader is a luxury tool. In the interest of furthering the craft, E-mail me and I will send you an alternative tool.
Regards
Rob
