Seeking suggestions on a first federal furniture project
Hi,
I want to try my hand building a federal style demi-lune table
I really like this one
https://www.finewoodworking.com/readerproject/2008/10/15/demilune-table-10
or the
Portsmouth Card Table done by Mario Rodriguez written up in American Woodworker some time ago
I am not sure this is too big of a jump for me and was considering building the smaller side table done by Steve Latta in FWW’s video workshop series.
As for my background, I currently enjoy building shaker style stuff mostly with hand tools (probably 90%) – I do own a table saw and a thickness planner, but I much prefer to not use them.
I would like make my own banding – and I am wondering of getting small bandsaw would be worthwhile.
I also wanted anyone’s take on using cherry vs mahogany – will cherry look very out of place – I do have a bit of cherry on hand and from what I have read there seems to be different kinds of “mahogany”.
Just to give you all a basic idea of my shop and modest skill level here is a little write up of a build I did a few years ago (my skills and tools have not changed too much since then, and I want to “grow”
https://www.lumberjocks.com/RobD/blog/116313
Any comments or suggestions are welcome,
-Rob
Do the Steve Latta table from the video workshop. All the information is there. It's similar to Shaker pieces you are familiar with. It's about as simple a Federal piece as you'll find, but it has elements of several new skills you'll need for Federal furniture.
I have built two Federal Card Tables. I took a class with Mario Rodriguez for my first card table and built another in my own shop. While I loved those projects and learned a lot, I must agree John_C2 and recommend the Latta side table.
The card table has several unique features, including bridle joints for the legs, bricklay (for the apron), and of course the veneer for the apron. There is much to learn and a good amount of details you can focus on. However, some of these things don’t directly transfer to other pieces.
If you want to use this project to enhance your skill set, the Latta side table has more skills that will be more relevant for your subsequent projects. Mortise and tenons for the legs, tapering the legs, and perhaps most important, an inset dovetailed drawer with cockbeading. Plus you can practice banding.
Best of luck with your next project. You can’t go wrong no matter what you choose!
I'll throw in my two cents here. I have started adding some federal style details to some of my projects and I would also recommend starting with the smaller table. I did look though you Lumberjocks posts and you have most of the skills to build the table. The base construction of federal style furniture is similar to shaker furniture. Mostly square surfaces and not much carving or flowing curves. The style is really based on inlays, veneers, stringing, and applied moldings. If you want to build federal style furniture, focus on gaining these skills and you will be well on your way. It has been a rough learning curve for me at times. Different veneers behave differently and the adhesive can make a big difference. I have started adding stringing, veneer, and moldings to the drawers in my shop just for practice.
As for banding, I have not made my own yet. I have purchased some just to add it to projects and it is a less expensive way to start. I have learned through trial and mostly error that a few thousands of an inch matter with veneering and building jigs to adjust for these differences is needed.
Feel free to use cherry or any other wood. There are no "rules" to furniture styles, only ideas. It may not look like a period piece, but pulling federal details into other pieces of furniture can be very beautiful. Garrett Hack uses many federal style details in modern pieces and it works well.
I don't think the table you want to build is out of your skill level, but it requires many new techniques. Start small, work on each skill individually, figure out your problems, and have fun.
Thanks all - I am wrapping up my last chest of drawers for my younger son now, but will start with the small side table first.
