Good morning everyone.
Can any one of you give me some help with methods to remove self-adhesive abrasive disks from a 12 inch sander. They always seem to tear for me and then I have difficulty removing the bits and pieces before I replace the disk.
Best regards to all
Woodsy
If you let them stay on they are there good and strong. I pulled my old one off and sprayed the disk down with wd40 and let it soak. I then use a razor scraper (walmart $5.00) to scrape the residual gunk off. It's a pain. I have to trash the disk to change grits. I'm going to switch from PSA to hook & loop. I know they are more expensive, but you can change grits without trashing the whole disk. I became a fan of them when I bought my PC ROS. It's nice to switch between grits and be able to get the most out of a disk and not have to trow it away after a single use. Take care
Thanks Bones
there is quite a bit to go on in your post. I will look around for some self adhesive hook and loop material and modify the disk for the future. The clean up with lacquer thinners worked reasonably well but now my hands stick together lol.
Woodsy
Woodsy,
I've used lacquer thinner to remove the glue and bits of paper from the disk.
Bill Arnold - Custom Woodcrafting
Click Here if you're interested in a good,inexpensive website host.
Thank you Bill.
Ive tried the thinners, it works fairly well but I could do without the smell.
Woodsy
I dont think I've ever gotten one to come off cleanly in one piece. If you wet down a rag with paint thinner and wipe the torn edges, you can usually get the thing to start lifting off in larger pieces some more. I used to try the same thing with acetone, thinking that it would disolve the glue the fastest. Not sure if maybe the acetone was evaporating too fast before it could soak into the disc paper, or what. But the paint thinner seems to work a lot better and faster. A flexible blade putty knife and razor blade scraper usually end up entering the picture before I'm able to get one completely removed.
If you build it - he will come.
Many thanks Douglas,
The thinners worked OK but the smell and sticky mess was a bit of a nuisance.
I think I will try to convert to a hook and loop system for the future.
regards
Woodsy
Yeah I know what you mean about the paint thinner smell. I've been buying the 'Odorless' kind. It's a tiny bit more than the regular stuff and isn't totally odorless, but it's an improvement.If you build it - he will come.
Once you get the disc off this time, lay the disc on a large piece of strong cloth and smooth it out before removing it. This will pick up fibers and cover a lot of the glue surface, which weakens the bond to the disc. When there is that much surface area holding the sandpaper on, it doesn't need to be so strong. I just went back and looked at the diameter of your discs. You don't need anything to hold on that well unless you spend a lot of time at the outside edge. I would try to reduce the tackiness and go from there."I cut this piece four times and it's still too short."
Edited 2/17/2005 12:51 pm ET by highfigh
I wonder if heating the disc first would help. I agree, it's a pain to remove them.
Don
Many thanlks Don. I'll try some heat.
Woodsy
Hot air gun or DW's hairdryer -- soften the adhesive, pull off the old disk and immediately slap on the new one.
IanDG
For removing one, I'd definitely recommend using heat first. That will soften the glue, works with all sorts of things.
Heat the disc by sanding for a 1/2 a minute or so, peel it off. You could use a heat gun if it doesn't come off easily. 80% of the time you do not need the heat gun.
mike
Thanks for the tip Mike
Woodsy
Hair dryer, razor blade scraper, patience and acetone for residual adhesive. Acetone's available as fingernail polish remover at most drug stores. I use the straight stuff, don't know what the scented stuff has as additives and don't want to find out.
Some of the scented stuff has mineral oil or lanolin added to it.
Thank you Leon
Woodsy
try xylene, marketed as goof off at the HD
No problem, Woodsy. Good luck.Leon Jester
