FineWoodworking.Com needs your help with a new set of videos about dust collectors. Send us the question you’ve always wanted to ask–What type of collector to consider. Ducting and blast gates. Troubleshooting. How to improve dust collection around table saws and other machinery. Whatever is on your mind.<!—-> <!—-><!—->
We’ll select up to 10 of the best questions to use in the video series. Roland Johnson, a longtime contributing editor to <!—-> <!—->Fine Woodworking<!—->, will answer the questions on camera.<!—-> <!—->
Post your questions here by February 15.<!—-><!—->
Thanks for your help and your interest in FineWoodworking.Com.<!—-> <!—->
David Heim
Managing Editor
FineWoodworking.Com
Edited 1/24/2008 10:01 am ET by David5346
1. What effect does distance between machine and DC have on dust collection performance?
2. How do you properly ground DC pipe?
3. What are the advantages and disadvantages of bag and rigid filters? (And which does a better job?)
What's involved in converting from manual to automatic blast gates?
Many of us hobby woodworkers can afford a dust collector but not a cyclone. I just bought a Jet 1 1/2 hp DC. How about some tests of the in-line garbage can with cyclone lids we can use to improve out DCs functionality. Do they work or not, or is it just a gimmick? How do the various ones out there stack up against one another? Any hints for setting them up and using them?
WoodlLess
I am considering a cyclone for my one man shop. I have limited room, however I have room in the attic of the shop/garage for the actual cyclone unit to be installed. I'm hoping to drop the chip collection bin/barrel back down into the shop, (away from the cyclone) for easy access for chip removal. The attic is not heated and I live in a hot summer/cold winter climate. I know that this will suck out heat from the shop in the winter if ran for any length of time. Will I have to build a insulated enclosure upstairs for the unit? Also, will it be too much for the cyclone to pull the saw dust/chips up that high and operate as it should? The ceiling in the shop is 8.5 feet tall. I have hesitated doing this for a long time because I could not find anyone to give me a yes or no answer on any of these concerns. Main sources of chips and dust are from a Unisaw, planer and drum sander.
Edited 1/24/2008 10:47 pm ET by cftrucker1977
Edited 1/24/2008 10:55 pm ET by cftrucker1977
Please address the "myth" of grounding DC systems. Is explosion truly a potential hazard? Don't we ground mainly to avoid the aggravation of static shock to our selves?
Here are several ideas:
My perspective is that I want my DC system to collect DUST. I care about my lungs, and less about the chips and shavings that I am not going to be breathing in anyhow!
Why not go out to some real shops with DC systems, run a few boards through the machines, then measure the airborne particulate levels.
What are US OSHA (or whoever) acceptable levels of airborne particulates versus standards in Europe, Canada, Australia, etc? How many CFM are needed at a typical tool (6" jointer, tablesaw, bandsaw, 12" tabletop planer, etc) dust collection port to meet this standard in a one or two car garage-sized space? Working backwards with a couple different 'representative' hobby systems (ie 20' of 4" PVC with a couple of turns, some blast gates, and a 5' drop of spiral hose to each machine) what kind of CFM do I need at the dust collector to provide this?
Comparing specs from different manufacturers. I've heard some provide CFM specs for their machines based on no filters in place! how about measuring a bunch of popular dust collectors and comparing their real CFM at their intake port versus what they claim?
I know my tablesaw and bandsaw spray dust all over me, even with the DC system I have. Is this a sign of a poorly sized system, or are shrouds inadequate?
I hope I don't come across as a cynic. There is a ton of DC system info out there, it'd be nice to see some new data on it.
Dan
Very good idea!
Looking forward to the videos!
1. How to design and build a dust collection hood for a stationary sliding mitre saw (chopsaw).
2. My main concern when upgrading to a permanent dust collection system with ducting and blast-gates and all, for my one-man shop is: will it be strong enough? What is the most important parameter when choosing size: hp?, CFM?, ... Maybe you could suggest models of collectors for this need?
A dust collector only does so much. How about tips on how to make machines more efficient on collecting dust in the first place. You know... blocking gaps to create more suction, building dust hoods, downdraft tables...
Chris @ flairwoodworks
I think the biggest question on my mind is the economic vs. safety question regarding differing materials used in duct work. I have yet to hear of anybody's shop exploding because they used plastic ungrounded plastic pipe (though I have seen it in compressed air applications), yet there sure are a lot of cautionary tales out there. As a small business owner, I'd rather just keep on using shop-built and plastic fittings. I know the metal benders have to make a living, too, but it's just not worth it to me.
Dust Collection!
I would like to know when FWW is going to run a meaningful test on the most popular "Dust Collectors" sold?
I read DUST COLLECTION DEMYSTIFIED in FWW and got rather frustrated with the information. Any of the popular equipment sold today can suck up the larger particles but what about the dust?
Assume:
So again my question for FWW and Roland Johnson is:
I would like to know when FWW is going to run a meaningful test on the most popular "DUST COLLECTORS" sold?
How about some strategies for modifying a single stage dust collector to keep fine dust out of the filter.
I would appreciate ideas for collecting /controlling dust during sanding operations
