I have a question for anyone who can answer it! After studying the usual construction of traditional case pieces, and after successfully building quite a few pieces of furniture, I am now faced with building a women’s-style dresser, the kind with two sets of side-by-side drawers, three drawers on a side. The question is, how does one build whatever needs to be in the center, between the two sets of drawers? I have looked and looked at plans and drawings, and none of them are clear to me on this one point, and it’s the only point I don’t seem to grasp. I’ve thought of any number of ways of doing it, but none of them satisfy me. I’m worried about how to keep the middle from sagging over time, about how the two drawers next to each other can be definitely kept at the same level, etc. Any ideas? Thanks!
Are you referring to a vanity? Is it a "sunken" vanity or is the entire top on the same plane? What are the overall dimensions? Think "small desk".....
Dano
Many thanks for responding! I should have said that this is not a vanity at all, but is instead a chest of drawers, with six drawers, three on each side. The whole thing is one top, and the two sides (or ends) go all the way to the floor, without any legs. It's cherry, 57 Inches long, 30 high, and 18 deep. I know all about the construction of the two outer ends, but I don't understand the construction of whatever is in the middle, where the two sets of drawers meet each other. Is there some sort of inner wall, and if so, how does one make sure that the whole thing will be kept level with the outer walls, etc.? Thanks!
Roughly, what are the dimensions of the vanity, and what are the approximate dimensions of the top, legs (sides?)? What kind of wood is being used, or has that been decided? Dano's question about the top is a good one. Is it on one level, or is the seating area between the drawers sunken?
Seems like there would be a number of ways to insure that the top remains straight, but I need more information and particulars...wb
Many thanks for responding! First, this is not a vanity at all--in fact, I guess I should have called it a chest of drawers, because that is what it is. This is a cherry chest, with a top and two sides that go all the way to the floor, no legs. It is 57 inches long, 30 high, and 18 deep. We have three drawers on the left and three on the right. I understand the outer ends of the construction process just fine. What I have never been able to figure out adequately is what kind of construction one uses in the middle, where the two sets of drawers meet. Is there some sort of inner wall, resembling the two outer ends of the chest, and if so, how is it constructed? Or are there some vertical boards strategically placed, or what?
I would definitely have some form of vertical wall in a chest 57" wide. There are a number of ways that this could be done. Either dadoed or dovetailed into the top and bottom, or going to the floor with a left and right bottom slotted into the wall, it is also dadoed or dovetailed into the back effectively tieing the chest together and providing a place for drawer guides or drawer hardware.
Seems to me the drawers would have to be made smaller than the drawer fronts, approx. the size of your center support or partition. I.E. If you use 3/4" partition in the center, then your drawers will be the inside dimension minus room for slides etc., and the drawer fronts would need to be 3/8" larger, each side, than the drawer box's, to overlap the center partition.The type of slide you use will dictate the amount of differance.
I want to thank you very much for your great ideas about how a vertical wall could be handled in the middle of that chest of drawers! Sometimes the most obvious things are the best, and would you believe, the greatest favor you've done me is to remind me that simply putting a bottom on that chest would tremendously help toward solving my problem. Not only have you given some great suggestions, but you have expressed them very clearly. Problem solved! Thanks a lot! -- DavidPino
