Hi everyone-
I’m trying to cut some 4.5 inch 38 spring crown for cabinets. Few 90 and a few 45 outside cuts. I’m using a 10″ compound miter with short fence (Hitachi) so can’t do the upside down against the fence method. I was wondering if there is a trick to setting the saw for those fraction angles ( for example 36.29) that are given on the chart when cutting crowns flat? Do I just need to buy a better saw with bigger fence or one with micro adjustment? Do I use a good digital angle finder and set the saw by that for every cut? Any advise would be greatly appreciated!
Crown
Is it possible to attach a taller wood fence to the existing metal fence ?
SA
crown moulding cutting
I cut all crowns flat on the compoud saw. You have to simply make a pencill mark on the degree scale at your desiried settings acuretly.Then swing the saw to your marks.
