I want to shape some standard profile, 3/4″ x 1/2″ base shoe. What is the size of the roundover bit required. I’m guessing its 3/4″ but I don’t have a sample handy to measure and don’t want to buy the wrong size cutter.
If you want to fully round over the top edge you need a bit with the same radius as the thickness of the stock, in this case 1/2". If you intend to round over the entire face of the molding then a 3/4" or larger radius is needed. It all depends on the profile you are trying to achieve.
Edited 11/17/2006 5:46 pm ET by JohnWW
Thank's but that won't give the standard profile. The curved front intersects the back serface at a slight angle and, I think, the bottom front edge is parallel to the back edge for maybe an 1/8th inch.
I think the closest you will come to a ready made bit is a 'thumbnail', sometimes called a 'table edge', bit. You can set it so that it doesn't cut the fillet if you only want a smooth elliptical edge. Lots of manufacturers make them, some in different sizes and some with less elliptical shapes. There is one on this page that is fairly inexpensive and has a nice profile. They can be more expensive.http://www.bladesllc.com/arouter7B.htmlBeat it to fit / Paint it to match
There are two styles of base shoe mold bits available @ http://www.eagleamerica.com In the search box type in part #'s
169-0605 and 169-0705
I would vertically run extra wide stock through a router table then rip off the profile, Much safer than running small stock.
Bruce S.
Thanks for the lead. Buying a dedicaated bit will be easier than thinking about it. Safety tip well taken. I use feaather boards and sometimes even glue on extra width.
