All,
How do you flatten your shapton ceramic stones? Have you bought the laping plate or can you get satisfactory results with granite and fine w/d sandpaper…if so what grit? thanks
BG, why don't you just try flattening them with sandpaper and see what works? That whole lapping thing they sell seems suspect to me (I saw it demonstrated at a show) because over time the plate itself will wear.
Mark,
"That whole lapping thing they sell seems suspect to me " exactly. For $128 dollars can't I buy a perfectly flat extention for the cabinet saw?..ain't that cast iron? And then there's the dirt in a bottle for $16 and $26 ...wow! I'm just a bit chicken to assume sandpaper and granite will work and thought I'd ask first.
I'd go so far as to guaranty that granite and sandpaper will work. Ultimately the proprietary lapping system just consists of a flat surface and an abrasive. That describes granite and sandpaper as well, with the benefit that the sandpaper system never wears out.<!----><!----><!---->
To test, just draw swirly lines on the stone with a pencil, then rub on the sandpaper (with water as lubricant, of course). When the swirly lines disappear, it's flat. I'll bet it takes all of about four seconds.<!----><!---->
Spend the $128 on something worthwhile - I'll give you the address of the Democratic National Committee if you like.<!----><!---->
mark,
lol...I guess you watched the hearings...I'd rather send the money to the Princeton Club, give Kennedy a heart attackGood idea with the lines...I'll try it
Mark,
I wet down some W/D and stuck it to the granite..it works well on the ceramic. good idea, thanks
From what I've read, ceramic is harder than anything except diamonds.
DonC,
They do cut quite quickly and are low maintenance(so far I haven't done any maintenance)..and it's hard to spend the money.
I was watching Jacques Pepin(sp?), the chef, sharpen his knives...." and in a pinch, just flip over a dinner plate and use the ceramic bottom to sharpen the knife"...gees.
BG, I don't know about ceramics, but scrap (used) plate glass and SC W/D paper works fine for me.
It might not be flat to the last half-mil, but it works well for me.
