Avid sharpeners,
I have some hollow back Japanese chisels which I really like and also 1000 and 6000 grit waterstones which I use to sharpen them. The water stones work well but are soft and loose their flatness quickly. What is the best way to reflatten them? Also, the 1000 grit stone is not aggressive enough to quickly reflatten my chisels. I like the way the water stones work but can’t find a stone more aggressive than 800 grit. Are there aggressive water stones somewhere or is there a better way to do the rough work on my chisels?
Sorry for any breaches in net etiquette, I am new at this.
Thanks for the help!
Hoov
Lee Valley has a 200.
Alan
I keep my stones flat by rubbing them against each other. You might try a lapping plate and abbrasive powder for the backs of chisels and plane irons, or I've heard good things about diamond stones. Good Luck
I flatten my waterstones on a 3/8" thick glass plate. Got it as a rem from the local glass shop.
I lay a sheet of 220 wet or dry sandpaper on the glass, pour on a heavy puddle of water, and move the stone in a figure 8 pattern.
The stones get visibly flat within a couple of minutes.
To flatten the back of a chisel, I use that same 220 sheet of paper and a puddle of water on the glass. It the quickest way i have found. Once the back is flat I'll go through sheets of 320 and 400 before switching back to the stones.
I like the porter cable self stick sandpaper--just rip off a section of 120 or 220 and stick it to your jointer bed and that will give you a nice flat stone. Then you can go up to 400 or 600. For the finer side of your stone, I use a piece of Mylar or plastic and put pumice or rottenstone mixed with water on it and polish it out with that. The reason plastic works better than glass is because the abrasive embeds in the plastic whereas the glass just allows the abrasive to roll around. Happy flattening!
You can also buy a ceramic contraption from Woodcraft that is supposed to keep your waterstones flat and true. To reduce the wear on such a fine grit stone, perhaps an investment in diamond stones would aid & abet in getting the worst of it out when sharpening tools, and you can save the waterstones for the final few licks. Incidentally, you can use a diamond stone to flatten a waterstone, now that I think about it.
" To the noble mind / Rich gifts wax poor when givers prove unkind" - Wm Shakespeare, Hamlet, III,i,100
Nothing fancy generally needed, guys. Got a cinder block (US) or breeze block (UK) kicking about? Flop it on its side and rub your waterstone on the face. It takes about 20-30 seconds to to do the job usually.
Just double check with a reasonably reliable straight edge that the face of the block is actually flat in the first place. Most are, but the occasional clunker gets through. Clean the choked block--after many flattenings-- with a jet of water from a hose pipe. Slainte.
Website The poster formerly known as Sgian Dubh
