In regard to how sharp is sharp; It depends on what it is. If a knife for the kitchen, you want a super sharp edge for effortless slicing. A super sharp edge is not what you want on a chisel or plane blade. The edge would be too fragile and would dull quickly. The test I use to determine sharpness, is to press the edge against the top of a fingernail at an angle. If it slips, it’s not sharp enough. If it wants to dig in, the edge is good to go.
Actually, for the kitchen, you want a little jaggedness in the edge (as seen under a good microscope) - that is where you get your cutting from
( I am also a cook and have reseached sharpening knives ) I do agree that a super sharp edge on a chisel will dull or chip almost on the first pass though. That is where the secondary bevel comes in.
Rick, you are dead right. I suspect Comrade Seatoe is being mischievous. In addition I would hate to see the state of his nail varnish if he were a full time cabinet maker(;)Philip Marcou
I was using Japanese style knives as the sharpness criteria and also the knives made by Furi. Furi knives use a sharp vee edge without any secondary angle. They are made in Australia and have a special sharpening tool for their maintenance. I do use a secondary angle on chisels and plane blades. I don't press very hard on the fingernail. Just enough that it will slide (not sharp) and tendency to dig-in (sharp enough). I use the scary/sharp method of sharpening these tools. When sharp, I then buff them on a cotton wheel charged with jewelers rouge until they are mirror bright. I find they stay sharp a long time.
Edited 6/21/2006 12:24 pm ET by seatoe
Edited 6/21/2006 12:36 pm ET by seatoe
The fingernail test is as good as any. I use it all the time.
I consider sharpening a necessary nuisance. Some here make a career of it.
Edited 6/20/2006 2:25 pm ET by BossCrunk
Curious. My experience has been that buffing (particularly with a cotton buffingwheel) a honed edge rounds it over and destroys the sharpness. Not only my experience but pretty much the concensus of everything I have read on sharpening. Carvers sometimes buff (preferably with a jute buffing wheel), but it will certainly round over a plane iron or a newly sharpened chisel. It does make them nice and shiny though.
"I do agree that a super sharp edge on a chisel will dull or chip almost on the first pass though. That is where the secondary bevel comes in."
I'm not trying to pick a fight, but it sound to me as though you may be confusing sharpness with the appropriate bevel angle. I can hone a mortising chisel to just as fine an edge as a paring chisel, but I wouldn't think if striking the paring chisel with a mallet - not because of the sharpness, but because of the bevel angle.
-Jazzdogg-
I agree with Jazzdog. Sharpness is a loosely defined term; so I think more of the quality of the honing . My carving tools and plane blades are equally well honed, but the carving tools are by definition “sharper” because of the more acute grind angle, and therefore they are more fragile than the plane blades.
I’m a fanatic about sharpening, but I don’t invest a significant amount of time doing it. I go through two grits on an oil stone, 4 grits of sandpaper and a polish with diamond paste. I don’t bother with jigs; they just get in the way.
Rob Millard
Not surprisingly, you and I appear to see eye-to-eye on this one, Rob.
I see sharpening as comprising two processes: (1) Shaping the cutting tool to a shape suitable for the task at hand, and (2) Honing (replacing larger scratches with smaller scratches) - also to a level suitable to the task at hand.
I wouldn't describe a tool that has a razor-sharp edge, but the incorrect geometry (shape), as properly sharpened any more than I would describe an obviously dull tool with the proper geometry as properly sharpened.
Many turners don't spend any time honing their gouges - they go back to work immediately after grinding; that's the level of sharpening (shaping & polishing)suitable to the task they are performing.
I've seen novice carvers hone parting tools until they shined like a mirror without first correcting the basic shape; despite the fact that these tools were undeniably well-polished (honed), their shape wasn't suitable for the task at hand - their tools weren't suitably sharp.
At its most basic, Knotheads can probably agree that a sharp tool has two surfaces (e.g., the back and bevel of a plane iron) with an intersection of zero width.
However, it seems to me that any meaningful discussion of sharpening must acknowledge the suitability of both the shape and polish (level of honing) of the tool under discussion.
Thanks for sharing your valuable experience!
-Jazzdogg-
Edited 6/21/2006 11:36 am by jazzdogg
Edited 6/21/2006 11:38 am by jazzdogg
Edited 6/21/2006 11:39 am by jazzdogg
