Here is a question. I am honing chisel and plane blades. Using an LV MK II honing guide and 1000 & 4000 waterstones I can get great results though it occurred to me today that I may not be paying enough attention to honing the flat back. I do this once, maybe twice at the beginning and end of the process, however should I be doing this throughout? Any tips would be great.
Also a friend is runs his own sharpening service and dips his finished edges in hot wax to protect them until use. Is there any practical around the house substitute I can use? I live in Bermuda where the salty air will very quickly corrode the honed edges.
Seasons greetings to all,
GWB,
A polished back to the blade should only need to be done once, when you first get it. After that, you only need to pass it over a strop a couple of swipes to break off the wire that forms each time you (re)hone the bevel.
I keep my spare blades in a made-for-the-purpose leather thing that holds six blades separately (it cost £10 from Axminster Tools in Britain - there is surely a USA equivalent somewhere). I give the whole caboodle a spray of camelia oil, to keep the moisture out.
If you can't get camellia oil, mineral oil will work, too. Paste wax is fine but nothing with silicone.
GWB,
Using a back bevel by way of the "ruler trick' ensures a super sharp outcome. Their is a video that David Charlesworth put out (LN sells it) or you can catch a snipet on http://www.thewoodworkingchannel.com
Anything I want to keep away from the air...I store in recycled ceral bags.
Edited 12/16/2006 8:40 pm ET by BG
