Where can in take my table saw blade to get it sharpened and what is a reasonable price to pay for something like this? Can i take it to the same guy who does my kitchen knives and hand plane blades? Or is it some special thing?
If you have a woodworking tool store nearby, they probably have a connection to a sharpening service. You may also find someone in the Yellow Pages.
You should also make sure that whoever you talk to actually knows about sharpening table saw blades. A properly sharpened blade is a joy to use, but if the sharpener isn't familiar with the correct techniques, they can turn a good blade into junk in a hurry. - lol
Dave,
I have a 42 tooth blade with 3.2mm (1/8th inch) ATB teeth that probably needs sharpening - it is geting a bit harder to cross cut thick stuff, even after a thorough cleaning.
I was thinking of trying to do it myself (a hone rather than a sharpen). In your experience, is home-sharpening a non-starter? (I was going to use a 1200grit diamond stone on the tooth faces - about a dozen "rubs" per tooth).
Lataxe, Old Boy. How are things on your side of the pond?
You don't mention the brand of your blade, but if it's one that you spent a fair amount of money on, I would strongly recommend having it sharpened by a pro. From what I've seen, there's a lot more to a good sharpening job than just making a few swipes with a stone. If you feel that you just have to give it a try, practice on an el cheapo blade. It doesn't hurt as much if you really botch it up and decide to toss it. - lol
I've been known to use my Dremel tool and a tapered stone to touch up my chain saw, but I'm not terribly worried about nice cuts with it. - lol
Another Forrest user here. I have sent several blades to them and they always come back better than new. Great service at a great price. Following is their sharpening service page:
http://www.forrestsawbladesonline.com/forrest_saw_blade_sharpening.html
Lataxe, I have "honed" the edge on several inexpensive blade just to see, and it does refresh them for a while, provided you don't get them too dull before you start. I used dmt stones, the red for three swipes, and the green for three, (sorry can't remember what grits those are), and a dissecting microscope to look at the edge.
I made a simple jig from some plywood to help keep things stable. A forty tooth blade took about an hour to do.
Jigs,
On the grounds that a half dozen careful swipes with the diamond stones, especially stabilised with a jig, cannot do irreparable damage, I will give your recommendation a try.
The local Woodcraft store (Canton, MI) does sharpening. You might check with one in your area. Who ever you have do it, be aware that sharpening a carbide-tipped blade is very different. If that is what you have, make sure they have the knowledge.
I send all my blades to Forrest for sharpening. They come back as good as new. And they do blades that are not made by Forrest.
Another vote for Forrest, they are the ONLY place I'll send mine.
I had a woodworker II sharpened through a local Rockler. They did a poor job. I just sent it out to Forrest. Also, I have a 12" chopmaster that i put through the fat end of a wood screw. I initially thought the blade was a complete loss. But i sent it to Forrest and they did a great job fixing for me. I will only use Forrest for my blade sharpening
