Does anyone have a line on sheets of velcro hook material. I’m looking to cover a drum sander so that I can change grits easier if I want to. I need a minimum size of 26″ x 26″.
57" by up to 75
57" by up to 75 feet!
http://www.mcmaster.com/#hook-and-loop/=av6sdj
better yet
See if you can find the hook material that festool uses, the hooks catch in two directions. If you do install regular hook on your drum sander, be sure to it in the non-slip direction. It is directional. (look closely)
