From Popular Woodworking:
Dewaxed shellac is more water-resistant. You can remove wax from regular shellac by letting it settle and then decanting the liquid.
The shellac you buy at the paint store is almost always a three-pound cut, which is very thick for brushing or spraying. Thin this shellac by half with denatured alcohol and make adjustments from there
If there’s too much water in the alcohol you’ve used to thin your shellac, it may turn milky-white….Use a purer alcohol.
Do you agree with this information, and what brand of alcohol has less water?
Janet
Janet,
I'm in the process of applying shellac right now to draw fronts. The 1 1/2 pound cut is a joy to work with. I'm not sure how many coats I'll apply, but I fugure 6 will probably give me a sufficient base to rub out with parrafin oil and 600 grit paper.
I used the flakes with Behlens (sp.) instead of the alcohol. I have no idea how you tell if the alcohol has too much water in it.
Is Behlens the brand of alcohol?
Janet
janet,
Behlens makes a liquid that is specifically designed for shellac flakes...they claim they dissolve better.
The product name is Bekhol, it's a proprietary solvent that, as you said, is specifically formulated for shellac. It's really superior to denatured alcohol.
Thanks Jeff for the correct spelling.
You had it correct, the product name is Bekhol and it is produced and marketed by Behlens.
j
Do you know if it can be used on wood that will contain food? I'd ask Behlens directly, but I can't find a website for the company.
Janet
janet,
Shellac is very safe..and the solvent evaporates...they use shellac in candy.
But, shellac does not stand up to water well..
Edited 1/9/2003 5:49:25 PM ET by BG
As has been already said, shellac is very safe (it's actually a natural substance, a secretion from the Lac bug).
as for Behkol, it's a solvent that evaporates when cured (I'm pretty sure it's primarily alcohol... and we all know that's somewhat safe, except when it makes us do dumb things!)
Janet-
Really, just mix your own shellac. It's as easy as making Kool-Aid, but you just have to let it sit for a few days before use. When mixing your own, you can buy de-waxed shellac or with the wax. As for the alchohol, use very good quality denatured anhydrous (aka no water) alchohol. I've been testing some pieces for the first time ever with shellac (mixed my own) and I love it. Read more on these following websites for more expert info.
Good sources for shellac include, but are not limited to:
http://www.rockler.com
http://www.shellac.net
http://www.woodfinishingsupplies.com
Go for it!
Kevin
the brand of alcohol doesn't matter there should always be declared the percentage or degrees of alcohol which should be minimum 94% pure alcohol. The remaining 6% is basically water. Shellac will disolve in a number of solvents ethanol is usually the cheapest because you don't pay for a "brand name" and works fine.
Philip
Another thing to keep in mind is that alcohol will absorb moisture out of the air. If you live in a humid climate and are forgetful about recapping your alcohol, the concentration printed on the label might not be very meaningful.
I think that's probably what Popular Woodworking meant in the original post. I have been getting good results with regular denatured alcohol from the hardware store.
Just to clarify some of the earlier posts, denatured alcohol is 95% ethanol (the "active ingredient" in rum, gin etc.). The other 5% is methanol, which is toxic and added to make the stuff undrinkable. All the alcohol evaporates when the shellac dries, leaving a safe, non-toxic finish.
HTH
Graeme
Yes, the information is correct. It seems counter-intuitive that shellac without wax is more water resistant than shellac with wax but that's the way it is.
Janet, if you accidentally get a bit of water in the alcohol or alcohol/shellac mixture, or if you find out that the humidity is too high on the day you apply the shellac, and you get that milky-white bloom when the shellac dries on your piece, it's very easy to correct.
Simply moisten a clean rag with alcohol and lightly swipe it across the milky areas. The alcohol should dissolve the shellac just enough and allow the water to evaporate, clearing the bloom.
David
Look, I made a hat -- Where there never was a hat!
