I have a small machinist chest I stripped,sanded, and then stained. Since it is an old piece, I thought shellac might be a nice finish. I intended to use Seal Coat, but what was handy was the bullseye clear, which I now realize is waxed shellac. I have applied a few coats using a water color brush with reasonable success. It seems as if my best option for any topcoat other than shellac is to use an oil based varnish? Are there any other options?
JR
Personally I would stay with the shellac, Looks good, traditional and easy to repair.
I'd stick with the shellac also, especially after using the waxy shellac. You will be risking adhesion problems by applying varnish ( or any other topcoat besides shellac) over it. If you had started with dewaxed shellac you would have been o.k.
Malcolm
http://www.shellacshack.com
There wouldn't be anything wrong with just continuing with the shellac. If you are going to use it and it gets dinged, it will be easy to repair. It will be a nice finish.
JR,
Really the only finishes you shouldn't use are poly or waterborne finishes.
Rob
Thanks all... I will stay with a shellac finish, it seems to suit the already dinged up character of the piece, although it is a very glossy look. From what I have read, the way to make the finish less glossy is to use 0000 steel wool after it has cured. Are there any other options such as 2000 sand paper and some mineral spirits?
hotwheels,
4-0 steel wool will give a very soft satin finish to the shellac surface which I think will be very appropriate to the piece.
But steel wool will not level the inevitable bumps, ridges and other surface irregularities of the shellac. It will simply polish all those irregularities with its abrasive pattern.
Shellac should be leveled before final rubbing out. Leveling is done with a sanding block (rubber or felt) and 220-320 grit sandpaper (I use 320, but I also level between each shellac application). Leveling removes a lot of shellac and you probably will need a few additional coats, which (also get leveled) before the steel wool treatment.
Rich
Edited 5/7/2007 6:03 pm ET by Rich14
Rich,
Thanks. I have applied the shellac in a few session so far, leveling in between 3-4 sessions. I am going to do a couple of more, then let it cure and rub it out with the steel wool. Does one of the 3m pads that is also 0000 have the same effect or is there something special about steel wool?
John
I prefer steel wool. The 3M pads just seem to burnish. With any finishing technique, you really need to try each option on test pieces to see what you like.
wouldn't be my choice, but couldn't you put a coat or two of dewaxed over the waxed, then whatever else you wanted?
no
