I am spraying multiple layers of tinted shellac to create a glazed finish, using an hvlp sprayer. I’m using super blonde dewaxed flakes (cut: approx. 8 oz. flakes to 32 oz. of alcohol), and have been having a problem with the subsequent layers of shellac (never the initial coat) appearing to “melt” – in spots – usually an area about 1/4″ wide x 1 inch, sometimes larger …
The visual appearance is not the bloom associated with humidity – I am familiar with that. It looks like a finish does when you put stripper on it, but reduced to a tiny, minute scale of that. It cures hard, but leaves a “frosted” spot in an otherwise perfect surface.
I suspect the alcohol in the shellac is acting as its own solvent on top of the previous layer? I have tried modifying how far the gun is from the object being sprayed. It appears then that the shellac is almost drying before hitting the object being sprayed – totally negating the reason I’m spraying multiple coats to begin with. I have tried new mixtures of shellac – both with different shellac flakes and different cans of alcohol. There seems to be no discernable pattern to when this “melt” happens and when it does not – other than never on the initial coat.
Help?? Any suggestions?
"Another characteristic of
"Another characteristic of shellac is that it should not be built into a thick film."
Howie,
Don't you need to build up a thick-ish coat to rub it out, though?
Thanks, Howard ...
I accept the science behind it .. I'm still mystified why it does not do it all the time.
Why am I successful in spraying multiple coats (up to 5 or 6) most of the time, and then this problem shows up (seemingly) at random? I've been able to build up subsequent coats of shellac without any problem, and never had the crazing you describe ... just this spotted "melted" appearance.
I built about 300 gold leaf frames last year alone. This 'melt' only happens sporadically, and then possibly on 8 of 20 frames that are sprayed one after another.
Thank you for taking the time to offer some insight!
Julie
