18 months ago I made a sign board for a local deli. It got used, blown over, etc. I brought it to my shop to repaint, and I quickly realized the latex did not adhere to the primed molding from the big box, but it did adhere to the bare rattiatta.
I (actually my better half) have peeled the latex off ot the primed molding. and will scuff the rattiatta prior to repainting.
Question: Will dewaxed shellac bond the primed molding and fresh coats of latex? Any other suggestions?
Thanks to all in advance!
Pete
Painters use shellac, particularly pigmented shellac, as a spot primer to cover filled nails holes and knots but not as an overall primer. Typically, two coats are put on the knots and the entire surface is covered with a primer, oil or water based. The primed moldings are usually covered with dust and the "tooth" of the primer they use is gone, so to speak. You need to sand and apply your own primer before painting. Don't use shellac as an overall primer, the latex won't adhere.
I will sand, prime and latex.
Everytime I get talked into painting wood, I swear that is the last tome! Oh well, life goes on.
Pete
Use oil base paint.
oil based paint vs. latex
I will use oil based next time.
Thanks!
Pete
Where do You get oil base paint here in the USA ?I wish i could but not in NY that I know off.
Hilmar
Go to Sherwin Williams and ask for a quart of Pro Classic oil based enamel.
Oil vs. latex
I will use oil based next outdoor project.
I pulled the rubbery latex off the pre-primed molding, scuff sanded the painted rarriatta (which the latex had bonded to very well), used BIN primer on the pre-primed molding and 2 coats of latex paint. Will see over time.
If the latex still doesn't bond well to the BIN/pre-primed, can I pull it off and use oil based paint over the whole piece?
Thanks.
Pete
