I am going to have to miter the edges on several boards to about 47 degrees for a length of about 8 inches. As I have no table saw, I was thinking of trying to set up a shooting board and plane the miters (how do you spell miter anyway?) I have looked but cannot find any information on how to use a shooting board on an angle for the edge of a board. Could anyone steer me in the right direction on how to set this up, or post some pics or links to pics? Thanks.
Take a look at David Charlesworth's book Furniture-Making Techniques Volume two. There is a chapter called Shooting with bench planes. Hope this helps. It's spelled "Mitre" in the book.
Lar
You could also take a look at http://www.millard.demon.co.uk/planingpoints/planeindex.htm. The "Donkey's ear shooting board" is for edge miters.
Fred
Fred,
Good to see that I'm not the only Jeff Gorman fan around here. I think he's just great! He just has a good way of explaining things clearly and in a fashion that's very understandable - doesn't leave you scratching your head wondering what he's talking about.
Thanks. That does give me an idea of how to go about it. I will probably take a look at the book mentioned aboove also, but at least now I have a clue.
It seems like this would be a good fixture to build to shoot something common like 45 degrees, but this will probably be the only use I have for it at 47 degrees. Have ya'll ever seen one for edge mitres that the angle was adjustable?
(notice I reversed the e and r on the word mitre this time for good measure)
If this will just be a one-off deal, you could make the shooting board the usual 45 degrees, and rip a strip or two to act as shims. Put them under the workpiece at the appropriate position, and clamp or use 2-sided tape so the shim won't move on you. Just out of curiosity, why 47 degrees?
Fred, who worked through college in technical THEATRE.
It is actually not exactly 47 but pretty close. It is for some table aprons which would normally meet the legs at 45 degrees, but the legs are splayed out at 5 degrees which changes the angle that the aprons meet the legs slightly.
I do like the shim idea. I probably would be better off building one at 45 that way I could use it more often and then just shimming it like you said. Thanks.
Edited 4/24/2003 2:52:00 PM ET by petemoss
Fred,
Add my thanks for the cite reference. I'd forgotten it was in my seemingly zillions of bookmarks. Many of the techniques are consistent with those in David Charlesworths books (fettling and sharpening contained in vol. I; edge jointing and shooting boards in vol. II). These techniques had a dramatic, positive effect on my handtool use and overall results.
Cheers,
Greg
I just saw an article in FWW #144 page 100 titled "Shooting boards aim for tight joints". Written by Mike Dunbar with pictures, a good informative article.
Lar
