Need some help yall!….I think this is close to what I am looking for but need some input. Things you might need to know. I work outside because of no dust collection, which is why most everything is mobile. The dimensions you see will work but it’s tight. Thanks in advance you any help.
Chris
Chris,
Looks like an efficient use of the space you have with plenty of room to move things in and out. I have a question, however. With no bench or vise, where do you do your layout, joinery, and assembly?
Outside the shop I have a table with castors on one end so I can move it around. It's nothing more than a 4x8 sheet of Plywood with legs and braces. It's not flat....but that is becuase I can't keep it that way. Stays in the weather. I suppose I could build a smaller one to roll in and out of the shop with a sealed MDF top or something....but I have so much to do right now that will have to wait.
Thanks for the input. Would you place the tools on the workstations in any different order?
Wondering how well your SCMS works with no apparent support on left side of the saw. Here's a link to some some ideas for a small shop. Check shop #3.
http://www.woodmagazine.com/default.sph/wcontent_user.class?FNC=CategoryLink__Astory1_html___7___40
Hmmmmmmmm.......SCMS is located on the left side of the station. Good point. I'll have to think up some kind of drop down support or something. Anything else will change the length of the station to the point where it won't fit.
Thanks!
