I have a very noisey shop vac. It has an air diverter in the exhaust ourlet and that’s it. Does anyone have any idea for installing some sort of a muffler in this outlet to reduce noise? I’m thinking something made out of PVC.
As I understand it, boat mufflers are basically a tube with a series of baffles like what's shown in the attached drawing. I'd be curious to know if anyone thinks this could help. It would be easy enough to make with some PVC pipe and some sheet material like AZEK or something like that.
I actually built a housing for the shop vac and put it on casters so it sort of looks like a hand truck. I lined the inside with acoustical foam and put a 2-1/2" hole into the top into which I plugged and secured a small auto muffler- About 16" long. My roar-like-a-lion shop vac now purrs like a kitten.
In the Helderberg Mountains of NY
Windwoodtrader, that's a neat idea.
By chance, did you use a "glass-pack" muffler, popular back in the '50s? What about racing stripes (or, painted flames) and chrome casters? ;-)Seriously, excellent idea.
Ralph-
Non of that exotic stuff, just lowering blocks and chopped and channeled with fuzzy dice attached.(:-)
Windy Wood
You forgot the spark plug in the tail pipe to ignite the hot gasses on occasion!
As in a HOT Chick was walking by....
Mine was a 1949/1950 Merc. Split windshields.. What year I forget... Black Lacquer paint.. Many coats.. Chopped so the girls had to crawl inside through a window I rolled down! God life was good then!
Edited 10/19/2008 12:10 pm by WillGeorge
I found that the standard "muffler" for my shop vac was, essentially, useless, as you'd expect from a bent piece of plastic.
I built a box out of 1/2" ply (nicely cut and sealed joints), put it on casters (up off the floor), put in a vent for the muffler (it usually just falls out), and a tight hole for the hose. The tight-fitting door swings open at the back to roll out the full canister. This has cut the noise down so much that I had to listen to make sure I did not leave it running. So I dedicated it to my router table and put in an automatic switch.
Jim BELL
If you have the kind with a larger port, Home Depot used to sell one with the Rigid brand. I don't know if they still do but I had to put one on me since, apparently, I just HAD to buy the loudest one available at the time. It just pushes into the exhaust port and doesn't really do anything bad to the air flow. Small, too.
Do you not wear ear plugs or other hearing protection or do you just want to make it more quiet, regardless?
Highfigh, I have an old Craftsman shop vac. It is very powerful and works great, but it's loud. I wear ear plugs, but it would still be nice to quiet the thing down so others don't have to listen to it. I think my vac would probably take the rigid muffler. I'll have to look into that. Thanks.
Look for the FWW article on silencing your shop vac. I built the same box and it worked GREAT!
Bio
One more click and I would have found your post. I just posted a muffler plan from plansnow.com (free) in Workshop, but I'll post it again and delete the other. Hope this helps.
Any chance you could save the document in an older version of word (doc) or as a pdf file? Those of us that are not using the latest and greatest of Bill's program can't open it.
Thanks.
Hope it works. Looked OK here.
That I can open. Thanks.
When one of you actually get a muffler up and running (I mean quietly purring....), please post details.
-Jerry
Stillfigurinitout, that's just the type of plan I've been looking for. Thanks very much.
OK. I had some free time this evening so I constructed a muffler. I used a 4" section of PVC 24" long with a center core of 2". 4" to 2" reducers on each end. The muffler did not reduce the volume of my Rigid shop vac by any appreciable amount: it seems that most of the noise emanates from the grated area over the motor housing.
All is not lost. The shop-vac muffler parts could be adapted into a nifty explosive device should I ever decide to split logs like they do over at Popular Woodworking....<Gr>
-Jerry
Hi,
You can find a muffler at Sears for $12.99. They make a real difference. Therefore, I always protect my ears with ear muffs, even with the muffler installed. Another aspect is when I use the vac with a tool, I need my ear muffs anyway.
Best,
Serge- Learn from yesterday, work today, and enjoy success tomorrow -
http://www.atelierdubricoleur.spaces.live.com
