I was wondering if anyone could give a quick review of the shopsmith lathe. It seems like the base would be solid and large enough for a good general purpose lathe, but what about the motor? Is it powerful enough? Does it have adequate speed adjustments?
It serves as a light to medium duty lathe. The motor has adequate power but the problem comes in the speed range available. The lowest possible speed isn't low enough. I bought my ShopSmith about 20+ years ago and used it regularly for 10 years. It now serves as my lathe on which I do little work and a drill press which is adequate for my purposes.
Thanks. I was asking because they are a dime a dozen used, but as I feared, you get what you pay for.
I had a Shopsmith for years (since about 88). I just sold it for 450 about 3 months ago on craigs list back in St. Louis, and it was still in great shape. It mostly took up space for the last 5-10 years, but I still used it for the lathe (I don't turn that much though) and the boring and the disk sander. It will do what you want but you would want to upgrade the standard chuck and tail piece. Nova Makes a chuck for the ss. If you get one that was cared for and have the space it would do fine. Your not going to turn a large blank with it, but it will do. SS's were a great tool for someone with a small shop and does not mind change overs.
Thanks for the reply. I think I'll just save up and get a real lathe when I can afford one.
My ShopSmith(510) sits mostly in the corner. My problem with using it as a lathe is the the Spindle is on the sloppy side, with not too many hours on it, with much more play than a didicated lathe that has some "proper" bearings.
Bruce S.
