Oh, I forgot, I also have a Shopsmith, too. With the 4 in. jointer. Looking for same sort of advice as for the cabinet saw mentioned in previous post. Thanks.
As for the shopsmith, do you have the manual? It details what the mainteance calls for. If you don't I think it is available now on their website. You don't mention your model, but check out their site. Here is the link for tips on servicing different sections. I don't use mine much anymore since upgrading to individual machines, but here is a link. The big thing is to check the belt. If it's been a long time it could be frayed. Also the luburacation of the quil assembly is important. The manual is real good. Mine sat idel in a shed for about 3 years. I did a good lub and clean and she worked just fine. Good luck.
http://www.shopsmith.com/ownersite/servicetips/index.htm
Just a second for giving the shopsmith a going over before using it. The bearing that the speed control attaches to tends to need cleaning and lubirication. I have an old mark V that a "friend":) dropped off at my house and that part is the only part that has given me much trouble. The Jointer attachement works well but I cant figure out how to face joint a 12" wide board on it;).
have fun
Troy
