Should 3 1/4hp router make 1/2″ rabbet?
I’ve just ordered a 1/2″ tall by 1/2″ deep (THats cutter size)rabbet cutter to try spline some 2×6’s together. My soft start router has been having some troubles getting up to speed due to sawdust and whatnot inside the machine as its in a router table and a lot of dust falls down, and gets sucked through it. I was assuming i could simply route this daddo (basically, rabbet?) in one pass with a 15 amp 3 1/2 hp(yeah, right!) router. Its a craftsman, maybe no router could do this? Do you think my router has a problem? I saw a used porter cable 3 1/2 hp router at the pawn shop for $160 that looked decent. would this do the trick? What do you think? Help again!1
THanks
Kelvin
Sounds crazy but... why not use a tablesaw or a spindle shaper for this operation??
YES a 3 1/2 hp router should have enough b***s to handle that cut. Again, do not feed too fast. I would not try to take all the wood out in one pass. SawdustSteve
The 1/2" diameter bit should do the job in two 1/4" passes and a jet of air will blow out the debris. Don't be fooled by craftsman's horsepower ratings
They really mean the motor under extreme load will develop 3-1/2 HP momentarily before it 'Buy's the farm' All their motors are underpowered
Any motor when pushed to capacity, will draw maximum currant and develop extra 'Wind' It depends on what you mean by horse power!
Steinmetz.
KP
I got a 3 1/2 HP Milwaukee mounted in a table that's a hoss. Will it cut 1/2" in one pass? On most woods yes... But I'm not going there with hickory, hard maple and not even a thought given with lignum-vitae.
I don't find the necessity to go that deep with any wood including soft-woods. No sense to me to risk kick-back or ruined stock by taxing the router even though it will. If I were in a hurry (I'm not commercial, so I don't have to hurry) I would put a shaper in the shop to handle that task.
The results of taking a wee bit at a time are clean, controlled cuts without too much concern of butchering a piece of stock or personal injury.
Regards...
sarge..jt
" Should 3 1/4hp router make 1/2" rabbet?" Short answer: Not in one swell foop.
Kelvin -
I guess I have to dissagree with the consensus of the group. A true 3 1/4hp router should be able to make this cut in one pass - with the proper bit, that is. But it would be taxing the router to be sure.
But why use the router whan a dado blade in the table saw is so much faster not to mention safer (in my opinion).(?)
From Beautiful Skagit Co. Wa.
Dennis
KELVINPOTTER,
I would agree with SawdustSteve and Dennis , if you have a TS and a dado set try it . Maybe a 1/2" x 1/2" spline cutter instead of a straight bit would work better on the router . If the 2x6s are soft wood one pass should do it especially with a true 3 1/4 hp machine , a slower feed rate may also help.
dusty
You can do it but it is not a grand thing to do. You could break the cutter, smoke the router and if the cutter has a diameter <1/2" you'll bury the cutter in the work and rip the hell out of it (the work). No need for that.
Router Facts
Pulleeeze Folks:Do not recommend dadoing rabbets on this forum on the TS. We must be mindful of our friends across the pond, and their opinions that the dado is dangerous and illegal. Be politically correct folks.Regards,
Boris"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
Agree with Pat's opinion here, Kelvin.Try and bite no more than 3mm (1/8") each pass with the router, no matter what the bit - you'll end up with a smoother cut too. Our trade training.Cheers,eddie(who just looked at Pat's website and saw his credentials)
Potter--- I have an old PC cast iron stair jig and I have routed hundeds of stair stringers using a PC 3 1/4 hp router ( # 314) using 3/4" dia. bits with 1/2" shanks with no problems in oak, maple or plain 'ole 2x10 framing lumber. In 4/4 stock I routed 3/8" deep. In 6/4 stock I routed 1/2" deep. I routed in one pass because plunge routers were'nt on the market yet. It worked just fine for me.
