I just purchased a Stanley shoulder plane. The problem I have is the blade is wider that the body, on both sides. How do I “shave” off the extra blade without affecting the plane body?
Thanks in advance.
Dave
Thanks in advance.
Dave
Bluejay,
The blade on a shoulder plane is supposed to be slightly wider than the body. I think they do this so you can cut a dado or groove with it and the body won't bind in the material. Once you get used to it, it shouldn't be a problem.
Kind of like set on a saw.
Steve
Agreed but only a hair wider. He may benefit from making sure that the edges are smooth, by a touch up with grinder . Mine still had the marks left by the guillotine (which was tired).Philip Marcou
Thanks for the reply. Define "slightly" wider. The blade on mine is a heavy 1/16th on both sides. Yes, that bad. I could use a grinder to make it narrower, but I run the risk of grinding the blade "out of square". I was hoping there was a way that wasn't so aggessive.
Thanks again,
Dave
I'm no expert, but 1/8th overall sounds way excessive to me; my L-N #73 is somewhere around 1/16th overall while my Clifton 3110 is somewhere around 3/32...Mike Wallace
Stay safe....Have fun
.008 - .010 on each side = 2 printing paper thickness
Hilmar
You can file the blades for a bit more control. Personally, I have my blades flush with the body because I use them mostly for trimming. Many cases, I need to plane from both directions to avoid breakout. I don't want to have to shift the blade with each direction. If the blade projects past the body, it gets hung up on the adjoining face. Watch your fingers with rabbet planes, it's easy to nick yourself.Beat it to fit / Paint it to match
Bluejay,
For this type of grinding, I use machinists blue ink on the back of the blade, then scratch the lines in it you will grind down to. This way, you get them nice and square. I also think .005" to .010" on each side is enough overhang.
Thanks for all the replies. I got exactly the information I needed.
Thanks again,
Dave
