I’m interested in building this project, but the dovetails seem too involved for me. Do you thing a lock miter joint would be effective and strong? I know the the dovetails would be really strong, but was trying to make it a little less complicated. I like the design, just joint would be a challenge for my skill level. Ideas on different type of joint? Thanks for any opinions!
The only lock miter bit I ever used was a 3" scary-ass monster to be used only in a router table. One part was run on the flat and one standing on edge. I would not want to try that with parts that large and on end grain.
You could go with box joints, not considered as pretty but plenty strong and the handsaw/ chisel practice will help you build skill and muscle memory on the road to dovetailing your next project.
If you have a table saw, you could consider the Lock Rabbet Joint. I've used this joint effectively for case work. The following article in FW describes making this joint.
Bob Van Dyke Shop Tip: The Lock Rabbet Joint
(How to use the tablesaw to make a simple, sturdy joint)
https://www.finewoodworking.com/2007/12/26/bob-van-dyke-shop-tip-the-lock-rabbet-joint
Home made box joint jig plans for a table saw abound. Is definitely a viable alternative to dovetails.
Conversely using the table saw to cut dovetails via a custom ground blade seems to be in vogue lately. Articles on this site explain it. Blades are around $170 or so I think.
The Japanese just use dowels to make drawers easy to do and look great especially if you use contrasting wood for the dowels.hope this helps cheers.
If you're not planning on jumping up and down on top of the sideboard, I think any of these options would work. I'm a fan of dowels here since it wouldn't affect the overall look of the piece like a lock miter or lock rabbet would.
Normal miter and dominos? (or biscuits)
