Just got a load of silver leaf maple and I am looking for feedback on working properties before I surface it as once I do it will be nonreturnable. Decided to purchase it after making trip to supplier today and salesman showed me a couple nice bundles. I guess the normal soft maple I use is called red leaf maple. The silverleaf was less money, nicer widths, and better color, now I am second guessing my decision. I will be making faceframes, raised panel doors, etc..etc… I am wondering how it machines as it seems very lightweight and soft. Thanks James
Sounds like you might have purchased silver maple. It is a fast growing tree both in height and diameter, which means it will probably move alot when you mill it. And I think it gets fuzzy when you sand it. If it is what i think it is i, personally would return it and get something else.
James
Silver maple is a soft maple, but is still pretty darn hard, and very usable. I have used it very often, as silver maple is extremely abundant in the midwest. It machines and sands well, and works well with sharp tools. It will move, as maple is prone to do, so allow for it. When milled, brown streaks are often found in the lumber. If you have some nice, clear boards, then use them. Many times, alot of figure can be found in the species.
I was told by someone in sales at Kettle Moraine Hardwoods that Sugar Maple is hard maple and everything else is soft maple. That being the case, silver maple will definitely yield some very wide boards with varying color. If the one in front of my house dies, I'm having a friend mill it into some nice stock. It should come out to ~500 bf.
Black maple is also a hard maple.For the poster of this thread, silver maple is a great wood, actually better than bigleaf in some regards. It's commonly used in furniture so you have some good lumber there.Lee
I agree with you, silver leaf is probably more interesting color wise as well.
I use quite a lot of soft maple, I wish silver leaf would be more readily available here.
Not fuzzy at all.C.
Are you from near Fond du Lac?
I'm in the Milwaukee area and was talking with one of the people at the Franklin store.
i've made several pieces with silver maple as a secondary wood. and one client liked the way it looked so much that he asked ne to make a pair of 6' cd towers using silver maple as the primary wood. I found some pieces that had really spectacular quilting and they turned out very nice. it machines well. I did not notice any excessive mevement. you will probably find lots of figure when you start planing it, and some tan to grey color variations.
nice wood, lots of charachter, yes it is somewhat soft, but about the same as other soft maples.
i look forward to any oportunity to try working with a new species at least once.
