Instead of trying to modify a cross sliding vise to use with a mortising machine, I went cheap and simple. The design uses a drill press vise and the total cost was under $10.
The heart of the design was a piece of heavy duty shelf bracket that was left over from some long forgotten project. I attached this parallel to the to the base by drilling and tapping. I used round head machine screws. A flat head machine screw was tapped into the base to keep the plywood sliding base level.(rail_attachment photo)
A piece of 3/4 plywood was grooved to accept the “legs” of the shelf bracket. The drill press vise is attached with threaded inserts and machine screws.(bottom_slot). One of those lucky things – the round head machine screws minimized the contact with plywood and it allowed it to freely slide from side to side yet maintain the parallel setting.
It may take a little longer to set up than a cross sliding vise but it works well and will cut smooth wall mortise.
Not bad, You also dont have to crank on that "little" wheel on the cross sliding vises.
yes - it is wood amd not metal. like my mentor in shop class taught me 40 years ago- wood movement trumps measuring to the the 1/64h
The Pictures are a 'BIT' small.. LOL
Not sure what ya did!
