Hello all – I’m not “new” here – just changed my nickname from Rob to TN-LabGirl since I kept getting mistaken for a guy!!
My first home project since my 2 woodworking classes – adirondack chair for the grandson (practicing on the child size before I do the two big ones for my best girlfriend!) In the ww classes they provided everything – wood, screws, tools, etc., etc. First question – how do I know what size bit to use to pre-drill holes? I “think” it has something to do with the size of the screw shank absent the threads BUT how to figure that out?
Second question – we did countersink the screws on the nightstand project in wwII, but we used a manual countersinking bit/tool – kinda had a large U-shaped handle. I did find a previous post about countersinking doing a search here, and saw the information about the jackrabbit system. Not sure I’m ready to go there – plan to predrill all holes and do countersinks before doing ANY glue-ups etc. But if the tool like we used in the class is expensive it may be worth it to look at the jackrabbit.
and yeah, I know this is not really “fine” woodworking stuff like most of you guys do, but i do think most of first projects are going to be outside things – no reason I can’t do them in a “fine” manner with square pieces and good joints!
Robin and Molly & Sadie (the Wonder labs) “Wonder if mom could build us a loft in the tree so we can see what’s going on outside the fence?”
TN,
http://www.internetwoodworking.com/w5/screws.html
the above link may help a bit...
for countersinking, I use something similar to the jack rabbit and try to match the screw top size with the bit
TN~LabGirl: Check out the following web site they have the chart your looking for..
http://www.woodmagazine.com go to bottom of that page click on site map look for free woodworking charts click on woodscrew chart..
its nice to see more Woodworking Gals here.. Take Care.. ToolDoc
Proud Member of the Delta & Klein Tradesman Club & Milwaukee HD Club & Knots Bad Boys & Girls Club..
A Non ~ Member of the Knots Bandsaw Guru Club..
If you don't have a chart, just hold the screw up to a light and then try holding up drill bits till you get one which blocks out the shank, but you can still see the threads of the screw (e.g., they are not blocked out by the drill bit.)
