How do I get a Sketchup image into a Knots post ?
Tom
Tom
Tom,
I've seen them here in .skp and .jpg files. I believe Sketchup can import/export .jpg files. .jpg files (Jpeg) are compressed images that are very common. .skp files are specific to Sketchup.
Hope this helps,
Tom,
From Sketchup's File Menu, select "Export," then "2D Model," then select "JPEG" as the file type and give the file a descriptive name.
Rich
After you've exported the JPG you can upload the file via the Attach Files button down in the same row as the Post button. If you want the image to load in the post, you can put it on a photo hosting site such as Photobucket. Then right click on the image at Photobucket, choose Copy. Then paste here.
If you choose to post the actual SketchUp file, remember to post the SKP file and not the SKB.
Edited 3/13/2009 11:02 am ET by DaveRichards
Test post
Bob, Rich, Dave,
Thanks.
Tom
TOm, you're welcome.
A question for you. What are those lines and the blue face behind the right end of the 35" dimension?
Dave,
Those lines are the remains of an incomplete erasure.Tom
